Javierg
- 0
- Jun 16, 2015
Costa Mesa,
California
Hi.
I have a 1997 eclipse gst spyder manual all stock. It began blowing A LOT of smoke out the tail pipe. I bought a nice little rebuild kit on ebay for a garrett t25 turbo for 50 bucks. When i removed the tubo, i noticed it had a lot of shaft play (in and out + up and down) Everything was going well during the rebuild process, I replaced both journals, both small snap rings, both rubber o rings, and seals etc. When I had the CHRA assembled nice tight (spun freely with no shaft play) I decided to put some motor oil through the oil inlet to check for leaks, it began to leak a good amount of oil from the turbine seal and a very very small amount from the compressor side seal.
OK now my question is:
Is this normal? Do the seals on both ends begin to actually seal the CHRA when the turbine wheel starts to spin? Or is this CHRA trash now?
I would like to know this before I install the turbo.
HOW DO THIS TURBOS WORK. PLEASE HELP!!
