Please Support Rix Racing
turbo inlet size
wises4057
143
Mar 28, 2005
Wisconsin Rapids, Wisconsin
alright guys, I've got a stock 2g GST and going to build a boost leak tester for it(pretty sure I've got a leak), but I don't know what size the stock turbo inlet size is on the stock t25...can anyone let me know quick?? thanks
ok. thanks, I haven't had time to pull it off to check today due to work. it is still stock, so I'll get a 2inch coupler. again, thanks!!
I believe my BLT is 2" which worked for the t25 when it was slid past the inlet point and onto the actual compressor cover. It now works perfectly on my 16g inlt. If you want it to sit on your t25 inlet use the rubber spacer in your intake snorkel. Otherwise just clamp it to the compressor cover and it will work fine.
