kchaazz
- 1,168
- 78
- Oct 2, 2002
PENSACOLA,
Florida
So, a couple months ago, I was pulling a log, and I noticed that my WB gauge was reading lean in the 12- 13:1 range at wide open throttle (Im targeting 11:1 AFR in that load range). I backed off the throttle right away and began to troubleshoot. Wideband is an LC1, installed per instructions with the output shared between the EGRT and DB gauge, and it worked fine for well over a year before this started. After all the things Ive checked, Im leaning toward a bad sensor, but Im still not sure because the thing reads 14.7- 15 at idle and cruise, and goes to 22.xx under decel as it should. The basics are as follows: Denso 660cc injectors, Jay Racing in tank 340 fuel pump, FP 18g, fuel lab filter and afpr. Base pressure is 38psi, base timing is 5* BTDC, plugs are BR7ES, gapped to .024, wires are good, NGK. Im using Tunerpro RT to tune, and everything is set properly regarding the 2g maf comp, injector comp and deadtime, but if anyone is familiar and interested, I can send a copy of my adx, bin and xdf for inspection. The car runs absolutely great, other than not wanting to get into boost.
1. Tried a known working maf from a friend
2. Boost leak test, no leaks
3. Bought a new fuel pump, no change
4. Bought a new fuel pressure regulator because my old one seemed to fluctuate and was leaking a little fuel into the vac line
5. Tried a new gauge on the fpr, just to see if the gauge was a few psi off, no change there either
6. Checked voltage at the pump, its 13.xx
7. Set boost to just 9- 10 psi and still the afr didnt change
8. Set the load cells in the fuel map to 9.0:1 just to see if anything would change and there was still no change on the gauge at wot.
9. Pre sensor exhaust leaks- I took the manifold off, and took it to Bogussvo, and he found that the flange at the head side was warped, so he surfaced it for me. I also thought that perhaps the brand new DP flex section I put in was leaking, so I put the WB sensor upstream from it, but still there was no change.
10. I did a free air cal per the innovate instructions with no change
11. Changed the fuel lab element, no change
12. I even put in a set of stock 450cc injectors, set the comp and dt for them and nothing changed
