jakk220
- 1,319
- 312
- Nov 13, 2010
Akron,
Ohio
This is a thread in search of all the experienced builders tips, tricks, advice, as well as answers to some questions that I have for my 6 bolt build. I will be using Manley 8.5/1 pistons and Eagle H beam rods. My apologies if it is long, but it has been about 5 years since my last build. 6 years since I have built the motor in my 2g gsx with a fellow DSM'er which is still running strong at 30psi (knocks on wood).
1. The order of the rings should be as follows: compression ring 1, compression ring 2 and then oil ring, oil skirt, oil ring 2 all in the same slot correct? I know that the compression rings are directional. As in they can go in upside down. If I recall correctly, the rings that came with my Manley pistons were not labeled with the dot. So if they are not, which direction do the angled edges go? Same question applies with the oil rings and skirt.
2. If I recall correctly the oil skirt and oil rings should not need gapped? I know that the oil skirt should not overlap, but I can remember exactly how it should sit. It should be the proper size right out of the box correct?
3. I'm trying to prepare a list of questions for my machine shop and was wanting to see if any one else has some they can think of.
1. Do you belt sand your block surface?
2. Request bore sizes before and after
3. How much material was removed from the block surface
4. I would also like to have them match my pistons to the cylinders for me as they will have them to install the rods onto the pistons for me.
5. I will request to have the mains align honed. They should tell me if I need to change bearing sizes I assume?
4. For my ring gaps I am thinking .20 for the top ring and .24 for the bottom ring. The long term goal for the car is to be at 28ish PSI on an FP green. My guess is that the pistons will be .10 over and I am trying not to cut the crank as I know you are not supposed to.
5. For my rod and main bearing clearances I am aiming for about .0003 and will be using plastigauge to check them. I have never used the stuff so any advice would be helpful. I assume the entire rotating assembly / girdle should all be torqued down at once when using this stuff?
I know for a fact I will have more questions as I go, which I will add in the posts below. But for now these are the main things. Some people may say "If you are asking these questions you shouldn't be building an engine" which is not true. I have done it before and am confident in myself, it has just been a long time and I will not have anyone watching over me. So I am a bit nervous, yet excited at the same time. So all your guy's help is much appreciated. Thanks.
