Tri-metal vs aluminum rod bearings
Posted by lars y, Sep 2, 2013
Please Support JNZ Tuning
  1. lars y
    lars y Supporting Member
    138
    Joined Oct 11, 2007
    Halden, Europe
    I read up on the difference regarding the main bearings, but i couldn`t find much information about the rod bearings. Will the same principles apply on the rod bearings?
    From what i could gather the tri-metal bearings can withstand more pressure but the aluminum bearings are more forgiving.
    So in a high HP engine the tri-metal would be the better choice, while aluminum is cheaper and better suited for a stock engine.
    Thanks
    Log in/Register to remove ads
    My DSM:
    Loading...
  2. TSIfreek
    TSIfreek Proven Member
    1,644
    13
    Joined Dec 14, 2003
    cary, Illinois
    The aluminum bearings are way more forgiving to the crack shaft as they are a very soft metal. I use the aluminum bearings and have no problem with them. Alot of engine builders perfer the aluminum bearings as well. They are cheaper but dont let that fool you.
    My DSM:
    TSIfreek 1990 Eagle Talon TSi AWD
    11.27 @ 127 MPH
    Loading...
  3. BlackKnight2013
    BlackKnight2013 Supporting Member
    99
    14
    Joined Aug 22, 2013
    Longmont, Colorado
    Tri metal bearings are mostly used for high reving engines and can take a lot of abuse when they are set up properly and the correct series is chosen.
    My DSM:
    1998 Eagle Talon N/T
    Street Build
    18.160 @ 75.750 MPH
    Loading...
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
