Please Support STM Tuned
Transmission Instal Part 2
1.Support the transaxle assembly by using a transaxle jack.
2.Remove the connection bolts while turning the crankshaft.
3.Chalk mating marks on the flex plate and clutch pressure plate for easier installation.
4.Press the clutch pressure plate into the transaxle for easier removal.
5.Remove the transaxle assembly mounting bolt and lower the transaxle assembly.
INSTALLATION SERVICE POINT
(A) CENTER MEMBER ASSEMBLY INSTALLATION
If the dimension shown in the illustration is outside the standard value when the weight of the engine is on the body, replace the front roll stopper bracket assembly.
Standard value (A): 43 ±3 mm (1.69 ±.12 in.)
(B) DRIVE SHAFT INSTALLATION
Temporarily install the drive shaft so that the TJ case of the drive shaft is perpendicular to the transaxle.
CAUTION: Do not damage the oil seal lip by the serrated part of the drive shaft.
