Transaxle = Transmission? Same thing
Posted by Spanky12345, Jun 6, 2005
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support Ace Race Parts
  1. Spanky12345
    Spanky12345 Proven Member
    Jun 23, 2002
    22
    , Dallas_Tx
    Is the transaxle and the transmission the same thing?
    #1
  2. psychlow
    psychlow Proven Member
    Jun 30, 2003
    2,200
    13
    Colorado Springs, Colorado
    Yes - but technically, our cars have transaxles.
    #2
  3. speedy13
    speedy13 Proven Member
    DSM Profiles:
    Dec 5, 2003
    1,047
    8
    hollywood, Florida
    I believe it's called trans exle because its a tranversall gear box,meaning from side to side.where as the sr20det,jgze's type are called transmissions because the y ar from front to back of the car.regardless your transaxle is a transmission.one more point i believe i was leaving out is that a tranmission has the differential seperate from the gear box.someone correct me if i'm wrong.
    #3
  4. slider85
    slider85 Proven Member
    May 21, 2004
    450
    Langley, B.C._Canada
    NO. i don't know the exact difference but i believe the transaxle is used mainly for FWD and AWD. A transmission is used for RWD models. A transaxle also has a transfer case attached to it. once again don't know the exact difference but there are.
    #4
  5. psychlow
    Jun 30, 2003
    2,200
    13
    The difference lies in the fact that there's a transmission and a differential inside the transaxle unit, whereas standard tranmissions do not have differentials. A RWD relies on a differential inside the rear axle - FWD's and most AWD's have differentials in the transaxle to drive the front wheels.
    As a side effect, most transaxles are mounted transversely, while most transmissions are mounted longitudinally.
    #5
  6. Spanky12345
    Jun 23, 2002
    22
    , Dallas_Tx
    The guy at the "City Garage" said the transmission was "sealed." So I take he is a dunb-ass and they I can flush and refill the transmission flid of my 1G DSM NTon-turbo without much hassle?
    #6
  7. igs
    igs Proven Member
    Oct 27, 2002
    1,021
    Seattle, Washington
    trans - axle is when the transmission and axle are the same unit
    FWD is usually a transaxle
    our AWD has a front transaxle and rear axle
    most RWD have front transmission and rear axle
    #7
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
