Please Support STM Tuned
torque specs for oil pan????
MadrussianSVT
95
Jun 9, 2011
Minneapolis, Minnesota
so yeah, I did very quick search and didnt find anything. Can some one tell me what are the torque specs for oil pan bolts, drain plug and do I need to put on new gasket every time I remove my oil pan? thanx in advance!
The pan is 5 ft. lbs. and the drain bolt is 29 ft. lbs. Also the oil pan "gasket" (at least stock) is just RTV/sealant so yes, you would need to reapply it every time.
Refer here for all your future torque spec questions: http://www.dsmtuners.com/forums/articles-miscellaneous/382492-torque-specifications-specs-spec-nut-bolt.html
