Torque converter won't go on
Posted by webconnect, Apr 25, 2009
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support Magnus Motorsports
  1. webconnect
    webconnect Proven Member
    DSM Profiles:
    Dec 22, 2007
    336
    San Antonio, Texas
    I can't get the torque converter to go in all the way into the bell housing. After about 2 hours + dinner I was able to get the starter ring on the torque converter to be flush with the bell housing. However the torque converter now appears to be jammed. I can't spin it. Is this normal?
    :banghead:
    #1
  2. webconnect
    DSM Profiles:
    Dec 22, 2007
    336
    San Antonio, Texas
    I just tried to upload pics but my camera's memory card is corrupt. Sorry. I took it out and tried again. Now the starter ring is flush to the bell housing, and I can turn it. However I still think the converter needs to be in more. Like the starter ring is inside the bell housing by 1/4 inch. Is that right?
    #2
  3. webconnect
    DSM Profiles:
    Dec 22, 2007
    336
    San Antonio, Texas
    After about a total of 18 man hours on just trying to get the converter on, I succeeded! While the converter's starter ring was flush with the bell housing, I turned the transmission on its opposite end. I then started to spin the converter and push, and let gravity do the work. It when in ever so slightly. Now the starter ring is 1/4 inch inside the bell housing. And it spins. thank the lord.
    #3
  4. dragonforce
    dragonforce Probationary Member
    Oct 2, 2007
    19
    brooklyn park, Minnesota
    Is this the first time installing a tranni? good thing you didn't turn it over the engine. if torque converter is not seated all the way, you can ruin front pump assembly.
    #4
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
