Please Support STM Tuned
Tony's 2G Makes Terrorizing Power - 666 WHP / 525 WTQ - FP 35R - Mustang Dyno
Boostin Performance
396
200
Jan 7, 2014
Hoffman Estates, Illinois
Tony's 2g came across the boarder from Wisconsin, with only one thing on his mind......a 9 second time slip.
We put the finishing touches on his beautiful 2GA Talon which included rebuilding the trans with a Evo 3 gear set, and welding his center diff. Tony recently installed a tubular rear subframe, so a Boostin Performance Race Alignment and Corner Balancing setup was next on the list.
Last year Tony's 2G made 624 whp / 476 wtq on our Mustang Dyno, and ran a best of 10.2 @ 146mph in the 1/4 mile. This year it's a completely different animal, with a little more boost.... 666 whp & 525 wtq on a bolt on FP HTA 35R! We think with a better 60 ft (due to the welded diff), and this new found power, Tony's 9 second pass should be within his grasp. :)
MODS:
* Boostin Performance Ported Stage 3 Head w/ Kelford 272 Cams
* Boostin Performance Stage 3 Short Block -10.5:1 Compression
* Boostin Performance Ported Evo III Intake Manifold
* FP Bolt on HTA 35R Turbocharger
* Fuel Injector Clinic 2150cc Injectors on E85
* DSMLink V3 Speed Density Tune
Nice, sorry I missed that.
No worries! :)
Whooo fat power band can't wait to see nines from this car but hold up this year you guys run sevens with a car named Red Demon then Tonys 666 hp you guys make deal with somebody?
Haha. You would think right? But no, it's just Devin's great tuning!
I come back months later to the forums.......this still just blows me away. A BOLT ON! That's no dynojet either. Mustang dyno.
I would still be very impressed with this if it were a fwd/mt on a more "generous" dyno.
If it were an auto i would expect a 9.5 w that kind of TQ and HP. Maybe even lower depending on weight.
If i lived a bit closer i would've called y'all a long time ago. Keep up the amazing work
Went back to Boostin this May for a retune. I mixed my own fuel for E85.This was the result...
Man I have to say im impressed, your tuner must be a beast! Thanks for the pic. Nice clean work under the hood, the combo of the two manis and that turbo with those #s alone speak volumes. Keep up the good work. Catch can setup to turbo intake :thumb:
Following your machine subscribed!
Are those -10 lines on the vale cover? The car looks great hope to see you at the shootout this year.
They are -10 lines. The 90 degree fittings hit the hood, I had to cut away part of the structural part of the hood to make them fit. I should have had the fittings welded sticking straight out the side or right on the bend of the valve cover for a better fit. I hope to make it to the shootout this year too. The more power the car makes the more weak points that show up :-/.
They are -10 lines. The 90 degree fittings hit the hood, I had to cut away part of the structural part of the hood to make them fit. I should have had the fittings welded sticking straight out the side or right on the bend of the valve cover for a better fit. I hope to make it to the shootout this year too. The more power the car makes the more weak points that show up :-/.[/QUOT.
Yeah that's what I'm worried about. I'm hoping there's more room under a 1g hood guess I'll find out. Thxs for the info!
