420A Tips on how to get an awkward bolt out?
Posted by eziomandude, Feb 12, 2018
Please Support Strictly Performance Motorsports
  1. eziomandude
    eziomandude Proven Member
    197
    Joined Mar 23, 2016
    Dale, Texas
    As most of the 420a people know our crankshaft is in girdle. I have all of the bolts out except the one by the oim fiktee housing. I tried getting a wrench and it was so tight I couldn't get the wrench to turn. So I thought maybe an impact will work. I get the socket on and the bolt gets striped. Does anyone have any ideas??
    Log in/Register to remove ads
    My DSM:
    1995 Mitsubishi Eclipse N/T
    Street Build
      manual
    Loading...
  2. silvreclips
    silvreclips Proven Member
    748
    26
    Joined Jul 19, 2005
    Greenville, South Carolina
    It's been a while since I had a bottom end apart but I don't recall any troublesome fasteners the last time I split the bedplate apart.
  3. eziomandude
    197
    Joined Mar 23, 2016
    Dale, Texas
    I'm not sure how to come at this. My wrench won't grip on it.
    My DSM:
    Street Build
      manual
    Loading...
  4. dsmcrzy
    dsmcrzy Proven Member
    1,089
    191
    Joined Dec 20, 2009
    Trenton, Ohio
    You have to take the aluminum oil filter plate off to get to that bolt. It’s the only way to do it. Even if you get it loose, you won’t be able to fish it out of there.
    My DSM:
    1996 Mitsubishi Eclipse N/T
    Street Build
    20g   manual
    Loading...
    silvreclips likes this.
  5. eziomandude
    197
    Joined Mar 23, 2016
    Dale, Texas
    How would I do that?
    How do I get this pulley off?
    My DSM:
    Street Build
      manual
    Loading...
  6. dsmcrzy
    1,089
    191
    Joined Dec 20, 2009
    Trenton, Ohio
    That hex part inside the aluminum plate. It’s threaded on both sides of the hex. Once that is out slowly pry the aluminum plate up. There is a pin that keeps it from spinning. Be careful not to shear it off.
    With one of these. Autozone should have them for rent.
    Flywheel Puller (46 Piece), Complete Crankshaft Pulley Puller, Steering Wheel Puller by Shankly https://www.amazon.com/dp/B01MS1KM0L/ref=cm_sw_r_cp_api_l8KGAb9HXNPY0
    My DSM:
    Street Build
    20g   manual
    Loading...
  7. eziomandude
    197
    Joined Mar 23, 2016
    Dale, Texas
    Do I need to take the flywheel off to get the girdle off? I ask because I'm not sure. I would'v taken it off but the motor moved to much to get it off. So is it possible?
    My DSM:
    Street Build
      manual
    Loading...
  8. dsmcrzy
    1,089
    191
    Joined Dec 20, 2009
    Trenton, Ohio
    I don’t believe the flywheel has to come off. There is no interference between the two.
    Typically you remove it before so the engine can go on a stand.
    An impact gun typically makes that easier esp if those bolts haven’t been loosened in a long time/ever.
    My DSM:
    Street Build
    20g   manual
    Loading...
  9. eziomandude
    197
    Joined Mar 23, 2016
    Dale, Texas
    I'd use my air impact but the compressor is dead. So I tried my electric half inch impact and nothing. Not even a budge. But any tips on removing the compressor? I've got 2 out of the 4 removed but I can't get the bottom two removed?
    And. The flywheel does have to come off. Unless me moving and it moving the crank does something else?
    My DSM:
    Street Build
      manual
    Loading...
  10. dsmcrzy
    1,089
    191
    Joined Dec 20, 2009
    Trenton, Ohio
    I don’t follow... what compressor are you talking about?
    Have you tried a large breaker bar on the flywheel bolts?
    My DSM:
    Street Build
    20g   manual
    Loading...
  11. eziomandude
    197
    Joined Mar 23, 2016
    Dale, Texas
    My apologies. The flywheel doesn't have to come off. It was just stuck. Do you have tips on how to get the rods disconnected from the pistons?
    My DSM:
    Street Build
      manual
    Loading...
  12. dsmcrzy
    1,089
    191
    Joined Dec 20, 2009
    Trenton, Ohio
    Yes. Taken them to a machine shop... unless you have access to a hydraulic press. If you are sticking with a press fit rod (oem style), have the machine shop press them back in.
    My DSM:
    Street Build
    20g   manual
    Loading...
  13. dustyboner
    dustyboner Proven Member
    511
    150
    Joined Mar 13, 2016
    abq, New Mexico
  14. dustyboner
    511
    150
    Joined Mar 13, 2016
    abq, New Mexico
    to get the pistons and rods out of the block, your gonna wanna get a few cans of PBblaster. start spraying the PB on the top of the pistons and cylinder walls. once the liquid is about a 1/4" above the top of the piston. leave it for a few days then check it, refilll they cylinders with PBblaster when needed. once it get to where you can add PB and the next day its gone. let me know and i'll tell the next step.​
  15. dsmcrzy
    1,089
    191
    Joined Dec 20, 2009
    Trenton, Ohio
    The one I linked, I have used several times to get the crankshaft sprocket off the crank with out issue. That said the OEM tools do always work the best... esp with how rusty the crank is...
    My DSM:
    Street Build
    20g   manual
    Loading...
  16. dustyboner
    511
    150
    Joined Mar 13, 2016
    abq, New Mexico
    my bad. i saw the red box and thought it was the one from autozone.
  17. dsmcrzy
    1,089
    191
    Joined Dec 20, 2009
    Trenton, Ohio
    No worries man. You are always on point with solid advice and plenty of references to the manuals.
    My DSM:
    Street Build
    20g   manual
    Loading...
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrications OHM Racing Race Components Inc RockAuto Spultronix Performance STM Tuned Strictly Import Motorsports Tire Rack VR Speed Factory White Shed Speed
