godschylde777
- 668
- 319
- Jun 3, 2009
houston,
Texas
So I have a 6 bolt swap. I have a blacktop so the signal is inverted. I also swapped the wires at the ecm. When I replaced the cas, i put all of the marks on point. So here is my question. If I set TDC to factory #1 cylinder. Yet because I swapped wires, is it still #1? Which call do I use to set base timing?
