andytalon
- 277
- 7
- Mar 27, 2005
Boston,
Massachusetts
I went out tonight when it was dark and started to adjust my timing with a timing light. I noticed if I pointed it at my Adj Cam gears it showed the teath marks as if it were stopped, now my concern is it showed one tooth off. Is this accually the way my timing marks are, can somone else perform this, its making quite a concern. It looks as if I've jumped timing one tooth. I know this may not be clear but all you do is point the light at the gears and it keeps them in the exact position as if the car were off and you were doing the timing. I really just wanna know if this is anything I should be concerned about. The car runs perfectly fine.
