MattO
- 0
- Dec 11, 2002
Austin_TX
Hope everyone's Friday night is going better than mine!
Here's what I got...
I've been working on replacing the water pump, timing belt, tensioner pulley, auto tensioner, idle pulley, and crank pulley for two weeks now on my 96 AWD TSi.
I have the tension set properly to the "5/32 drill bit" but the holes on the tensioner pulley are at 7 and 4. Do they need to be at 11 and 2 for other reasons (dynamics, mechanical, balance, longevity)? I've tried to get the holes at 11 and 2 but the auto tensioner is completely recessed in the body if I set the holes there. Additionally it looks like the pulley will rub on the water pump housing if the holes are at 11 and 2.
I'm using all Mitsu OEM parts from Conicelli.
I searched and found various ideas. Some are more concerned with belt tension vs. hole location. The VFAQ for the process shows the holes on top.
Any ideas? Thanks. MattO
