timing belt/burnt rubber smell
Posted by aznlangjai69, Feb 26, 2004
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support Strictly Import Motorsports
  1. aznlangjai69
    aznlangjai69 Proven Member
    Dec 15, 2003
    89
    vancouver, B.C._Canada
    Just got my car back from the mechanic shop yesterday and I noticed that there is a grinding (metal against metal sorta) noise coming from the timing belt area. It usually comes when at idle, and when it's acelerating, it goes away though. I took my car into my garage and popped the hood and I can smell a little bit of burnt rubber. Anyone know what's wrong with it? I did crash the front of my car, could something be loose or too tight? It's so loud that I can't even hear the engine running and when I was at work, my co-worker told me something was wrong with my engine from like 2 metres away.
    #1
  2. boostnbuds
    boostnbuds Proven Member
    Feb 19, 2004
    106
    Warren, Rhode_Island
    You need to be a little more specific when describing symptoms. There are a lot of things near the timing belt that could grind and smell like burnt rubber. When you popped your hood, did u take the timing cover off and check it out? How do all of your accessory belts look, are they rubbing and burning up? :thumb:
    #2
  3. aznlangjai69
    Dec 15, 2003
    89
    it's not the burning that is the symptom, nor is it bothering me. It's the sound that its making. Its like metal grinding against metal. My friend said some WD40 might work, but I wanna be more sure.
    #3
  4. andymoraitis
    andymoraitis Awaiting Email Verification
    Jan 25, 2004
    3,013
    134
    Utica, Michigan
    I wouldn't try to fix or diagnose something that could be potentially serious after your mechanic gave the car back to you. Take the car back, explain the problem and make him fix it, especially if it wasn't happening beforehand.
    WD40 is some great stuff, but grinding metal sounds and the smell of burnt rubber (which you should be concerned about) isn't it's forté.
    Good luck!
    #4
  5. Defiant
    Defiant DSM Wiseman
    DSM Profiles:
    Jan 13, 2003
    25,202
    111
    glorious Galt, California
    Take it back, make them repair it.
    #5
  6. aznlangjai69
    Dec 15, 2003
    89
    it happens once in awhile, and i've experiment it before, but still can't tell whether it's on cold days or hot days. it happens before on both hot and cold. sounds like one of those old ford trucks. just doesn't match an eclipse. =p
    but for sure i'll let my mechanic take a look at it. he won't lie cuz he's a relative.
    #6
  7. DragII
    DragII Proven Member
    Oct 4, 2003
    28
    , VirginiaUS
    It's somewhat normal to smell burning rubber with new belts as they break in. also, don't get wd-40 on your belts, it can cause them to fail early. I'd take it back to the shop you had it done at, and have them fix the metal sound.
    #7
  8. mastaBO
    mastaBO Proven Member
    Oct 22, 2003
    96
    , --_United_States
    Wel i had my time belt done and i smell the burnt smell. I was afraid to drive it for some time. You think its normal? It was pretty stinky while i was driving home. Seemed to happen when i did some speeding.
    #8
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
