thumping in front end while driving
Posted by and1chewy, Sep 28, 2011
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support Miller Import Parts
  1. and1chewy
    and1chewy Proven Member
    Nov 25, 2009
    156
    Honeybrook, Pennsylvania
    so today a thump started in my front end for no apparent reason. it sounds to me like its coming specifically from the front left tire. im thinking it may be a front wheel bearing as ive though that they may have been going for a while now but i went from a slight noise to a defenitally noticable noise on ecceleration. at low speeds there is a slight whooping sound that gets faster as i accelerate. i dont think its my half shafts as i just had it inspected with no sign of wear. i didnt notice any great motor shift when i surge the throttle for the engine bay. ive read on here in two different posts that the lug nuts maybe loose which is a possibility that i will look into when and if it ever decides to stop raining. Just trying to get the expert opinions as im not great at diagnosis. i think that this is quite a coincidence but i ran through i pretty big puddle today as it was pouring pretty well on my way to work and vision was limited. but i drove ###### 20-25 miles before i heard any noise. also the thumping stops when i hit the breaks. like something is putting hold down pressure to hold whatever is thumping in place. and it is definatly a thump not a click as you would be used to hearing from a half shaft. thanks in advance guys/gals (i know your out there)
    #1
  2. 4g63tc
    4g63tc Proven Member
    DSM Profiles:
    Nov 20, 2002
    1,036
    6
    Palmcaster, California
    Did you check your Wheels weights to see if they're still there?
    #2
  3. Blue Talon Boy
    Blue Talon Boy Proven Member
    DSM Profiles:
    Sep 22, 2010
    262
    Leesburg, Virginia
    I would start with checking the lugnuts like you mentioned. I had a similar problem with my Accord about 20 miles before the tire fell off at 40 mph.
    Sent from my ADR6300 using Tapatalk
    #3
  4. SrKegler
    SrKegler Proven Member
    Feb 29, 2004
    917
    31
    Daytona Beach, Florida
    Check the lug nuts, what kind of shape are the tires in, check for a bulge in the sidewall. Does the steering wheel shake? Check your caliper bolts. Jack the car up and try and shake the wheel top to bottom and side to side. If there's movement, could be ball joint(top to bottom), tie rod end (side to side), or wheel bearings.
    #4
  5. and1chewy
    Nov 25, 2009
    156
    there arent any wheel weights on the outside i did get a look at that not sure if there was one there to begin with. i will check the lug nuts and the tire as soon a it stops raining and i can get out there. tires arent in great shape. the ball joints are in good shape as i said i just checked/had it inspected about 3 weeks ago and havent put more than 100 miles on it since. thanks guys you confirmed what i was thinking.
    #5
  6. goodbuds
    goodbuds Proven Member
    DSM Profiles:
    Nov 10, 2009
    337
    7
    oceanside, California
    warped rotors and pads..
    #6
  7. and1chewy
    Nov 25, 2009
    156
    Pads are at like 7-8/32 rotors are in good shape. Wouldn't warped rotors cause a shimmy when I'm braking as opposed to when I'm not? Gonna try and check the lugs when I get done work unfortunately I have a 96 jeep cherokee I'm working on for my mom and moms come first sometimes.
    #7
  8. 68442
    68442 Proven Member
    DSM Profiles:
    Oct 14, 2007
    501
    3
    Des Moines, Iowa
    Jack up the car and see if the wheel wiggles. Had the same noises that one day got worse quickly, thought it was my tranny but the wheel had a lot of play in it.
    #8
  9. DirtyJerzeyDsm1
    DirtyJerzeyDsm1 Probationary Member
    DSM Profiles:
    May 3, 2010
    19
    nj, New_Jersey
    i would start off by checking the whole front end ball joints make a thumping sound when they blow.if its only when u r turning it could be an axle i should be something to major to change...
    good luck
    #9
  10. snowmastergt
    snowmastergt Probationary Member
    Nov 4, 2010
    16
    Hinesburg, Vermont
    I heard a similar noise and it turned out that 3 of my lug nuts fell off my left front tire. Didn't scare me until I realized that I had been on the highway without 3 lug nuts doing well over highway speeds. :/
    #10
  11. and1chewy
    Nov 25, 2009
    156
    finally got out there today and had a chance to look at it. 4 lugs on the left front tire almost off. busted out the torque wrench torqued them down no more noise.
    #11
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
