boosted475
- 0
- Oct 20, 2009
san francisco,
California
hey guys I'm going to check out a 1995 Talon TSi AWD tomorrow. Just wondering if it's worth picking up. Also I've heard of reliability issues with DSM cars, do I need to worry about that as much with the motor built stronger? here is the ad:
"hi im selling my 1995 talon tsi.it is awd (all wheel drive) and five(5) speed manual.(car is the same as a eclipse gsx)car has 121k orig. on odometer so is on body. motor and tranny 3200k miles since built.car was built back in MAY 2004.car is rarly almost never driven ...weekends only
car was professionaly built down south at road race engineering speed shop down in san diego.NO expense was spared.it dosnt not have a 7-bolt 4g63t motor it has a jdm 6-bolt block and head 4g63t.car has dsmlink ecu flash eprom.
im asking $5500 firm im in a bind and need cash fast.......... my big loss your big gain.real dsm lovers know what rre is and how much $$$ can be spent.contact me for more info
here is a list of the work done to the car at rre as is on the purchase order receipt word for word
description unit price
VALVE TRAIN PARTS
crower spring and retainer 350.00
s/s swirl polished 1mm oversized valves 240.00
hks cams 280 exh/280 intake 550.00
ENGINE BEARINGS
clevite connecting rod bearings 60.00
clevite main bearings 80.00
OIL PUMP
new oem oil pump 1g with case gears and castle plug 175.00
balance shaft removal kit 50.00
GASKETS
mitsu factory head gasket 95.00
factory gasket set 210.00
ENGINE REMOVAL AND INSTALLATION 600.00
TURBO
turbo water hose 20.00
exh. nuts and washers,set 18.00
exh. studs ,set 22.00
modify 2g motor mount 15.00
modify 2g motor mount bracket plate 5.00
modify 2g timing belt cover 10.00
oem jdm mitsu tdo5h big 16g evo 111/3 turbocharger 1100.00
port and polish of turbocharger 150.00
wastegate delete 100.00
tial 38mm f38 wastegate 320.00
tial red and blue springs 60.00
punishment Elbow Outlet 38mm Pipe for wastegate 80.00
turbo Stainless Oil Feed lines kit 100.00
greddy type-s blow off valve (bov) 200.00
ENGINE MISCELLANEOUS PARTS
2g 95-97 cam angle sensor(w/wiring harness) 250.00
set of spark plugs(ngk b7es(4)) 40.00
CORE CHARGES
used short block 500.00
HEAD WORK
555 reurface head,grind valve seats,3 angle valve job 350.00
silicone bronze valve guide set(8 intake,8 exhaust) 80.00
labor:grind valve seats for oversixed valves 100.00
stage2 port and polish head: match port,
clean around valve seats,and smooth ports. 400.00
fuel injector o-rings:upper and lower 14.00
TIMIN BELT PARTS
timing belt 67.00
timing belt hydraulic tensioner 1g 80.00
timing belt tensioner pulley 25.00
timing belt idler pulley 36.00
6-bolt water cooled filter housing new 80.00
water pump 1g 100.00
thermostat 1g 12.00
PERFORMANCE ENGINE PARTS
wiseco pistons 450.00
eagle rods 400.00
arp main studs 55.00
arp head stud kit 90.00
injen cold air intake 200.00
1g stock intake manifold 150.00
EXHAUST
apexi down pipe 3" 200.00
apexi 3" exhaust n1 400.00
2g stock exhaust manifold n/a
PERFORMANCE LABOR
balance complete assembly,blue print 200.00
deck resurface and reinforce 95.00
LABOR(DEPENDING ON CONDITION OF CORE)
strip to long block and re-assemble 300.00
build long block, clean, strip gaskets,
hone cylinders, check clearances, and assemble
6-bolt long block. 700.00
bore cylinders 0.20"(0.50mm)or 0.40"(1mm)oversize 150.00
polish crankshaft 80.00
line bore block 120.00
FUEL SYSTEM
walbro 250 200.00
jdm evo8(560cc) pink tops injectors 600.00
CLUTCH/TRANSMISION
shepracing.com stage3 Transmission 1975.00
bg syncro shift (3) 29.00
centerforce clutch 450.00
fidanza aluminum flywheel 380.00
LUBRICANTS
anti freeze 11.00
break in engine oil 15.00
k&n oil filter 6.00
total:$14,000.00
kelly blue book on car is $3700
$14,000,thats not including the car yet.. just mods!have ALL papers...once again im only asking $5000.00 frim on price for everything!
NO low balling car and mods together are $17,700 so $5000 is a steal
car runs 12.3's to 11.9's in 1/4mile as of now.with a bigger turbo like 50 trim could run 10's 9's.engine was built to withstand 35psi of boost
spec's on tranny
New 1-2 Fork New 3-4 Fork New Shep Trans Spec 2nd Gear New 1-2 Hub/Sleeve kit with Double Synchro Rings New 1-2-3-4- 5-R Synchro Springs New 5th Gear Synchro Rings New Input, Output, and both Drive Shaft Seals New Input Shaft Bearings New Intermediate Gear Bearings New Roll Pins New End Nuts New Center Diff Side Shims New Nylon Shifter Pad Shims for setting preload Upgraded Torrington Bearing Bead Blasted Case 4 Spider Center Differential Heavy Duty 3-4 Conversion Transmission filter upgrade Upgraded Rare Earth Magnet EVO III first gear and input shaft"
VALVE TRAIN PARTS
ENGINE BEARINGS
OIL PUMP
GASKETS
TURBO
CORE CHARGES
HEAD WORK
TIMIN BELT PARTS
timing belt 67.00
thermostat 1g 12.00
eagle rods 400.00
EXHAUST
PERFORMANCE LABOR
FUEL SYSTEM
walbro 250 200.00
CLUTCH/TRANSMISION
LUBRICANTS
anti freeze 11.00
k&n oil filter 6.00
total:$14,000.00
spec's on tranny
