Please Support STM Tuned
The dud
illestep3
42
7
Oct 1, 2016
Enfield, Connecticut
hi everyone hows it going im new to the dsm world, been into hondas since i was 15 and have always wanted an evo but could never afford one. To start this build off i pickedup a 1991 eagle talon awd for a parts car.
It has a carbon fiber hood, rx-7 wheels, braided brake lines, adjustable rear upper control arms, autopower bolt in roll cage, fluidyne radiator, 750cc injectors, apexi safc2 16g turbo, arp chromoly head studs, act #2600 clutch, apexi turbo timer, 2g piston and 1g rod bottom end and thats pretty much it. I ended up taking the motor, trans,and tcase out as soon as i got it home. Got the head off the motor and off the the machine shop it goes.
Then i went all out ordering some go fast goodies
-full blown dual fuel pump hanger
-2 aem 320 pumps
-fp intake
-jmf race intake manifold
-s90 74mm tb
-link v3
-fic 2150cc injectors
-jmf front bumper support
-fuel lab 8an fuel filter
-fic fuel rail 8an feed 6an return
-gsc s2 cams
-Aem cam gears
-gsc beehive springs
-hks timing belt
-Stm t3 exhaust manifold
-obx aluminum oilpan
-felpro mls headgasket
-precision 6262 gen one off my civic
-Precision 46mm gate off my civic
-precision 64mm bov
-Fluidyne aluminum radiator
-ets race intercooler with 3.5" core
-Brass shifter bushings
-silicone hoses
-N/A water pipe
-mighty max oil filter housing
-l19 arp headstuds
- 16ft of 8an braided line
-16ft of 6an braided line
And other odds and ends.
Now for the car all this is going into. I ended up looking for another 1g that was cleaned and one that didnt have a hacked up harness like the previous car, ended up finding a clean shell one of my buddys friends had laying around. I picked up a clean rust/rot free 1990 eagle talon tsi shell from Louisiana.
Once i got this car home the tear down began with this car, had to put my 91 shifter cables in, install a 4 bolt rear end i got with the car, put the rx-7 wheels from the other car on, cleaned up the engine bay, got the sending unit out, jmf bumper support on, adjustable rear upper control arms in, and fluidyne radiator all mocked in
I will be keeping this build thread pretty much updated with new pictures and recent work done i will deffinately need some input to help me get this thing done, thanks for looking
Update 10/16/16
Got my head back from the machine shop looks great and also picked up a precision 6765 for $250 , sent that in to get rebuilt and get a 66 turbine housing and turbine, also started making the lines for the fuel setup and fitting the fuel lab filter in the oem bracket, and running the feed line setup off the mighty max filter housing
Update 10/30/16
I got all my fuel lines ran and buttoned up under the car
Got my billet wheel pte 6766
Also got dsm link full
Also found out my block isnt saveable and has already been bored .040 over so thats going in the garbage and starting fresh
Have got a lot more done to my car including wiring up the dual fuelers, taylor cable battery relocation, fuel pump rewire, got my cop from night shift performance, mounted the turbo and wastegate on the manifold, finished all my fuel lines until the feed and return
Its been awhile since ive posted alot has happened with the car , i got the motor, trans,tcase,radiator,boost gauge,wideband,twin disc act,3 piece crossmember, mustache bar,stainless brake lines,coilovers in, flex fuel setup is in and much more
Got some 3" alphalocs for the intercooler setup, these things are bad ass hoghly suggest using them
Dropped off at kgfabrication for all the fab work and weld porn
Intercooler piping on the tb side all done, bov and iat are all on and intercooler and custom brackets are looking good, needed to get a speed factory half radiator and jay racing alternator relocation, alot more to but almost done
Lookin good bro, any talon revival is good in my book. Gotta keep that namesake alive. Hopefully you'll ditch the honduhs after this. I have an open spot in my garage I'm thinking a 1g would look good in, as I've never owned a 1g even though I fell in love with DSMs back in 90 with my spoiled buddy's panda.
I love watching guys spend a shit ton on new parts that I never would, I wait like a turkey vulture for the part out haha. Do you plan to keep your DSM indefinitely or are you the type to move on to the next project?
I love watching guys spend a sh** ton on new parts that I never would, I wait like a turkey vulture for the part out haha. Do you plan to keep your DSM indefinitely or are you the type to move on to the next project?
Thanks man im trying to keep this one alive, and this one isnt going anywhere, i usually keep all of my vehicles i still have my first car from highschool haha
Engine bay is looking alittle more complete, worked in looming my wire harness in spots just to give it some finishing touches , exhaust should hopefully be getting made this week
More fab work looking better and better ! Kg fabrication putting in work !
As for a wheel and tire setup i ended up going with vision 571's 15x8 +27
With hoosier qtp 26x9.5x15's
