jdub14
- 38
- 4
- Aug 16, 2009
toronto,
ON_Canada
Hey guys,
Which suspension is best for street and lapping? any suggestions?
Note: This feature currently requires accessing the site using the built-in Safari browser.
What about the d2 coilovers? I heard those were a good set for the price.Agree with Zmann, FEAL coilovers are currently the best bang for the buck currently on the market for the DSM platforms.
I think the time that they put into setting them up is the difference.
I've had bc on the same chassis as my koni's. The koni's handle better.
One of the things I don't like about most of the coilovers is the greatly reduced travel, and almost no sag. There is no way for the spring to push the tire down when the pavement is falling away for whatever reason.
Yes, but I haven't driven, or rode in a car with them. Something like that with a good progressive spring would probably work nicely.
Feal use pretty much the same shock as the BC with a 46mm piston but its piston design that counts and ODI from feal may have changed them making them slightly better inside. The swift springs do help aswell and of couse the fluid used has a good effect also,^This is why I'd choose Feal.
@SNAKE_15 I've heard (but not used myself) D2 and BC are good coilovers as well, but personally I'd choose Feal Suspension because of the R&D that goes into the setup for each platform.
A bunch more info here, and make sure you check out the thread on the Galant forums:
http://www.dsmtuners.com/threads/suspension-upgrade.501151/#post-153573222
Does anyone else with feals have a camber issue up front? I bought these a while back for a 1g chassis I'm working on and the camber adjustment looks like there is not much room to add negative camber. I have yet to have the car aligned waiting on an engine build so I am unsure.
I run them, i did a review on them on the forum,What you guys think about BC Coilovers?
