Archived Testing the waters
Posted by babell2, Mar 20, 2017
Please Support Miller Import Parts
  1. babell2
    babell2 Proven Member
    293
    3
    Joined Oct 27, 2002
    1990 Eagle turbo AWD in parts
    I was amassing parts for a total rebuild. Wife getting upset about parts scattered throughout the house and garage
    · 6 bolt block bored 20 over new 20 over pistons and rings
    · 7 rods to choose from
    · Block empty grinding out casting marks in block
    · New oil pump with balance shaft elimination kit WELDED to oil pump (will not fall out)
    · New ARP rod bolts
    · ARP head studs
    · New in box DXD clutch disk with pressure plate
    · Small 16G turbo W/ ported waste gate
    · Front mount intercooler with copper piping
    · Remote mount oil filter
    · 2.5 Stainless steel Exhaust from Turbo flange to rear bumper.
    · New Dorman lower control arms
    · New KYB 4 way adjustable shocks with 1.5 lowering springs
    · Transmission overhauled by TRE engineering with new 1GA output shaft and matching 1GA input socket in Transfer case. (23 Spline)
    · Walborogh 255 lpm fuel pump.
    · Upgraded fuel injectors
    · MAF translator with 3” GM hotwire
    · DSM to USB link cable
    · UEGO wideband O2 sensor
    · -6AN fuel rail fittings with Fuel filter
    · Turbo timer
    · Front brakes upgraded to 1GA 2 Piston calipers and rotors.
    · New gas tank filler neck
    · New rear suspension crossover structure with Heim joints for rear control arms and nylon body mounts
    · New upper rear control arms with Heim joints
    · New in box emergency brake cables
    · Front K member pulled cleaned and repainted
    · Hood Vented over turbo (in process)All metal construction.
    Pictures available on request
    Possibly other things I can remember now
    Log in/Register to remove ads
    My DSM:
    Loading...
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrications OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports Tire Rack VR Speed Factory
