Go4Long
- 0
- Mar 22, 2005
Calgary,
Alberta_Canada
alright I jacked the picture from another thread, but to make a long story short my 2.3 build has been nothing but a massive pain in the ass from day one...
I've destroyed the turbo center section twice, the second time while using an inline oil filter I still managed for something to go wrong...basically the car has been officially running for over a year, and I've driven maybe 5000 km because it's constantly parked waiting for me to figure out what the hell the problem is now...
after installing the turbo after the second failure I checked everything out and there was no leaks or anything, was running like a champ, boosted good...the whole nine yards.
Drove it home from strathmore to calgary(75 km or roughly 50 miles) no problem at all...checked the parking spot under the car, no drip...
two days later I drove it to work, got to work and there was oil literally running off of the cross member(err...whatever the one is that goes front to back) on the drivers side. let it cool off, checked the oil(added a quart), started it up, when it's cold no leak, but after a minute or two it started to drip out of the bottom of the timing cover.
took it to a local DSM guy here cus I was sick of dealing with it and his first shot at it is that it's coming from the head gasket...and quotes me $1200 to fix it...I was like "hmmm...I'll come get my car now thanks"
took it back home, tore the timing cover off it, hosed the whole mess down with brake clean, let it dry up then started the car...I would have assumed this guy had done some kind of expert diagnosis before quoting me $1200 to fix a head gasket, so I'm standing there with a flashlight pointed right at the spot where the head and block meet on the drivers side of the block, not a ####in drip...oil is pouring off the bottom of the block and there's no oil at the head. to the mechanic.
anyway...I'll cut to the chase now that I've bored you all half to death...it appears that the oil is coming from:
is that even possible? if not where should I be looking around there? if I do have to take that bolt out, is the timing going to go out when I take it out? so sick of this car all this money and still not even a 12 second time slip
