dont_blink
- 0
- Sep 1, 2007
Morgantown,
West_Virginia
I am having a hard time with this one for the suspension on my Talon. I have settled down to doing a full coil-over system of which there are two very good choices. If they were the same price or at least close the JIC Magic would get the pick hands down. Both systems offer camber adjustable upper pillow mounts.
The JIC Magic FLT-TAR set up has several obvious advantages over the TEINs. You can adjust spring pre-load and height independently. It has 15 way compression and 15 way rebound dampening adjustibility. It also uses a monotube design which is more conistently viscous through prolonged use. Linear springs and the rates are pretty close to what I expect to run with 450s in the front and 393 in the rear. I'm shooting for 350 in the front and 450 in the rear. I can get the fronts revalved FOR FREE from JIC to accomodate the loss of 100 lbs/inch, but I won't have to touch the rears. Plus the JICs look prettier .
The TEIN SuperStreet is an inherently inferior piece. Your pre-load also ajusts your ride height like many cheaper coil-overs. 16 way compression and rebound is a plus. But again, more isn't always better. It uses a twin tube damper which usually offers a better response but fades in a prolonged use application where it's in constant flux. Still linear springs but a little stiffer than hoped for (Remember Japan has MUCH nicer roads haha) at 504s in the front and 393s in the rear. I again would have to get the fronts revalved but TEIN charges $100 per damper for that. The only real advantage, besides price, to the TEIN system is that you can use their EDFC on this system to adjust damping on the fly. But I don't think I would ever use that and the controller is $200.
My hang up is that I can't touch the JICs new for less than $1700 and I can get the TEINs for about $800 cheaper than that being a TEIN dealer. Throw in the $200 to revalve the fronts and it's still $600 cheaper. Throw in the $200 for the EDFC and it's still $400 cheaper.
Is the $600 price difference worth buying the JICs? Or are the TEINS going to be enough on the rocky, rough roads of WV. I'm worried about high speed expansion joints or the lovely potholed filled roads of the area heating up the twin tube designed TEINs and having not such a consistent damping force after a few hours of driving.
I don't have the ability to post this in the suspension section or I would.
