PlanZero
- 1,516
- 263
- Aug 13, 2013
Easton,
Pennsylvania
On my girlfriends RS there's been several performance problems, including erratic idle, excessive exhaust (but no real loss of oil), sometimes an engine miss, occassional hesitation. I changed plugs, wires, compression is perfect, swapped the TB with one from my old GS with newer tps and IAC, cleaned IAT and MAP sensors (intake Mani is filthy). As I was fiddling around I noticed when I pulled the hose off the egr solenoid I could see some smoke sputtering out at idle. Could an egr stuck open cause all these problems?
