Symptoms of a bad timing belt?
Posted by Taylor3180, Jun 12, 2007
Please Support Kiggly Racing
  1. Taylor3180
    Taylor3180 Proven Member
    135
    Joined Apr 15, 2007
    Deposit, New York
    Just curious what the symptoms of a bad timing belt are. A buddy of mine heard me start my car and its squealin for like 5 seconds and goes away. And thats from a cold start but from turning the car off and starting it again it makes no noise. My buddy says thats what his did before it broke any truth to this i've never heard of that and when I take the top cover off it looks in pretty good shape.
    Log in/Register to remove ads
    My DSM:
    Loading...
  2. jim97gst
    jim97gst Proven Member
    456
    Joined Aug 2, 2002
    Tucson, Arizona
    The timing belt has teeth, so it won't squeal. Sounds like one of the accessory belts is loose. Tighten the accessory belts to see if it goes away.
    If the timing belt looks good, but you suspect it might have a problem, then you might want to check the tensioner as well. Actually, if you have no idea when the timing belt was last changed, you might want to go ahead and change it anyway.
    My DSM:
    Loading...
  3. Cs4g63
    Cs4g63 Proven Member
    1,179
    7
    Joined Jan 8, 2007
    Rosamond, California
    ^^^^ I agree.
    Your accessory belts are what is making the noise. You should inspect them for missing ribs, missing sections of rubber, cracks, or to see if they just plain look like crap. They are a simple and inexpensive fix.
  4. Taylor3180
    135
    Joined Apr 15, 2007
    Deposit, New York
    Thanks for the help I was just out looking at the car and noticed the belt for the power steering and I believe the ac was a little loose so a little tighten and it is fine I thank you for the help once again.
    My DSM:
    Loading...
  5. Eclipse98_RS
    Eclipse98_RS Proven Member
    211
    Joined Jul 15, 2006
    Otsego, Minnesota
    If you tighten the belts and it comes back that means the pulleys could be bad too. I have had to tighten my belts 2 times now. Definitly NOT timing belt though.
    My DSM:
    Loading...
  6. Defiant
    Defiant DSM Wiseman
    25,202
    123
    Joined Jan 13, 2003
    glorious Galt, California
    You have a blown harmonic balancer.
    My DSM:
    Loading...
  7. flyinghighlm
    flyinghighlm Proven Member
    327
    4
    Joined Sep 27, 2005
    charleston, South Carolina
    yep yep, same issue I had and thats what defiant told me it was, spent the 90$ on a new one and the problems are all gone. I spent a month chassing sounds, wish I would have known this sooner,LOL.
  8. Grescht
    Grescht Proven Member
    154
    Joined Apr 1, 2008
    New Kent, Virginia
    I was told my harmonic balancer was blown.. but it turns out it was the PS belt the whole time. When the belts slip they get a glaze on the inside of them that most of the time no matter how tight you make them, they still slip. I replaced the belt tightened it up nice, and no squealing.
    wow, this thread is old... LOL
    My DSM:
    1997 Mitsubishi Eclipse GSX
    12.949 @ 105.680 MPH
    Loading...
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
