Symptoms of a bad map sensor?
Posted by jdmawd, Dec 2, 2002
Tuning & Engine Management - 4G63 EPROMS, ECU, MAF, knock, EGT, wideband, datalogging, fuel trims, etc.
Please Support Kiggly Racing
  1. jdmawd
    jdmawd Banned Member
    Mar 20, 2002
    2,391
    GreenBelt, DC_Metro
    anyone ever had a map sensor go bad, if so what were the symptoms. here is the deal under part throttle or wot. it seems like the map sensor is not reading the increase in manifold pressure. while the turbo is spooling, until full boost is reached. i have checked the tps and it reads correctly. basically pressing the gas pedal and watching the percentage value on the s-afc progressively from 0-100%. fuel pressure is consistent and linear as the boost level rises. It appears that for some reason the vpc is not adding fuel until full boots is reached. also there is huge amounts of knock in the area also. The a/f gauge goes from cycling to red to no bars at all until full boost is reached, then knock goes away and the a/f gauge reads normally again. also i have tried different vacuum source location with the same effects. will map sensor line length, effect the sensors ability to read manifold pressure. the hkc hand books asks for 4" total length. mounting the map sensor on the fire wall, above the manifold makes that impossible.
    #1
  2. jw
    jw Proven Member
    Dec 19, 2001
    392
    The manual states how to check if the MAP sensor is working correctly. You can use a bicycle pump to pressure the sensor to see if the voltage are within specs. I know at atmospheric pressure (gauge pressure at 0psi), it should read around 1.74v.
    #2
  3. jdmawd
    Mar 20, 2002
    2,391
    GreenBelt, DC_Metro
    cool thanks
    #3
  4. NJGSX96
    NJGSX96 Proven Member
    DSM Profiles:
    Dec 11, 2001
    694
    YMB, New_Jersey
    I have the manual on my site if you want to check...
    http://www.databurstpc.com/data/hks_vpc_manual.pdf
    Tuning the AFC by MAPp is a little different than by TPS.
    What is the gain and response set to on the VPC?
    What is the HI/LO throttle positoin at on the AFC?
    What are the LO settings on the AFC?
    What are the HI settings on the AFC?
    #4
  5. jdmawd
    Mar 20, 2002
    2,391
    GreenBelt, DC_Metro
    i still have it wired up in the conventinal configuration. basically the safc intercepts the gray air flow wire from the vpc harness going to the ecu.
    gain is at 12 response is at 5
    LO throttle is 30% HI is 70%
    LO settings are-17 across the board
    HI starts at -15 and prgressivly ends at -8 by 7K
    base fuel pressure 38
    base timing is 5*
    boost level is 22 psi
    #5
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
