WhyAmIDoingThis
- 0
- Apr 29, 2017
Spokane,
Washington
OK so I've never done this but I am I'm looking to change my gs 4g64 n/t spyder to manual using a 98 Gs spyder 4g64 n/t donor car. I've already pulled the manual trans with 100k on it, the mounts, the ecu and plugs, the starter, and the shifter assembly.
I know I still need:
Pedal cluster
Clutch master cylinder
Shifter cables
New line from the master to the slave
Manual center console
Flywheel
Clutch disk
Pressure plate
Throw out bearing
What am I missing on this list?
Will the ecu from the manual work without flashing it? What modification to the auto harness do I need to make and what sensors do I need to change out?
I'll change the ecu to an evo later but for now I'm looking for advice on a STOCK changeover
Pedal cluster
Shifter cables
Flywheel
Clutch disk
Pressure plate
Throw out bearing
