Supercharged 4g63
Posted by JayRome, Dec 12, 2008
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support Miller Import Parts
  1. JayRome
    JayRome Proven Member
    Dec 12, 2008
    133
    40
    Victoria, Australia
    might be a long shot, but has anyone supercharged their 4g63 N/A and have a modded base map for a VR4 Eprom'd ECU (for a supercharger)? running stock 450's and 1g maf?
    [​IMG]
    #1
  2. e85_4g63
    e85_4g63 Proven Member
    DSM Profiles:
    Nov 17, 2008
    1,400
    9
    Manheim, Pennsylvania
    There are a few supercharged 4g63's around. I don't think anyone has a "base map" per say, but you could probably use a turbo ecu. Although the timing map for a 1g is very aggressive. I'd advice wiring in the knock sensor if you do so. By VR4 I assume you mean the Galant and not the 3KGT / Stealth correct?
    *edit* after rereading your post, I have some more to add. Forced induction (supercharged or turbo'd) share the same principals, so in turn, a turbo ecu should handle the blower just fine. What setup do you have? Do you have a logger?
    #2
  3. JayRome
    Dec 12, 2008
    133
    40
    Victoria, Australia
    yes sorry, E39A VR4 Galant..
    i am running the full VR4 set up minus the turbo... its been doing fine for a while now, just want to pull a little more power out of it, before i drop a completely different engine in this project..
    edit: setup
    Hi comp N/A (close to 11:1)
    eaton M45 from a C200 Komprossor
    4-1 tuned length extractors
    Vr4 ECU (can be eprom'd)
    450cc's
    1g Maf
    onlything is that the supercharger boosts soo early, the VR4 ecu hasn't been able to compinsate for fuel at lower RPM's.. so i can hear slight pinging which i have adjusted Via an SAFC2, but it can only go so far... and no, i have yet to build a logger for this car, i'm waiting on the carputer for that...
    #3
  4. Kastigir
    Kastigir Proven Member
    Sep 22, 2008
    237
    Cincinnati, Ohio
    Outside of how they make boost, both applications are similar. Your normal turbo ECU should be fine, might need minor modifications. I know a guy that has a VW Corrado G60. His SC fried so he went out and got him a comparable turbo. IIRC, it required very little tweaking to run hard.
    #4
  5. cheap90gsx
    cheap90gsx Proven Member
    DSM Profiles:
    Mar 15, 2008
    225
    puyallup, Washington
    engine management such as dsmlink shouldn't have a problem tuning with a supercharged application.
    #5
  6. e85_4g63
    DSM Profiles:
    Nov 17, 2008
    1,400
    9
    Do you have a 1:1 FPR on the car? You could (as a temporary band aid, although I don't recommend it) pull back the base timing a couple degree's.
    #6
  7. 97 4G63
    97 4G63 Proven Member
    DSM Profiles:
    Mar 27, 2006
    464
    3
    RALEIGH, North_Carolina
    I don't want to jack up this thread but why would anybody want a super charger?? over a turbo
    More torque?
    #7
  8. Kastigir
    Sep 22, 2008
    237
    Cincinnati, Ohio
    Instant boost?
    #8
  9. JayRome
    Dec 12, 2008
    133
    40
    Victoria, Australia
    thats correct!ROFL
    in saying that i get about 4psi from idle and 8psi from 1.8krpm
    everyone in australia seems to have a huge turbo attached to a 4g63 (well thats on my cordia anyway)... so i thought why the hell not, build a supercharged hi comp 4g63...
    works pritty well actually, and considering my car is set up for cornering, you dont really have to rev out the engine to get power.. in saying that i get 11lt/100km fuel economy with start stop city everyday driving.. so no complaints.
    i have an Malpassi FPR currently set to 48PSI under load, i am also maxed out on neg timing on the CAS. its all holding up pritty well soo far and its been a few months now..
    it was Dyno'd when i first built it, but the old ECU didnt like the boost and tiny injectors so it ping'd off its nut.. although in saying that i did get a safe 57kw at 38% throttle.. with the VR4 stuff in i havent had time to get it tuned and dyno'd once again...
    i will have more look into the DSM link, was also thinking of shoving a 6G72TT in the project but i want to see how much a supercharged N/A will make before it blows LOL...
    #9
  10. cheap90gsx
    DSM Profiles:
    Mar 15, 2008
    225
    6g72tt would be savage.
    #10
  11. xreaction122
    xreaction122 Proven Member
    Oct 28, 2007
    227
    Albany, New_York
    wow. S/C'd 4g63 is deff. something different
    you need to take a video of this
    #11
  12. JayRome
    Dec 12, 2008
    133
    40
    Victoria, Australia
    speaking of that....
    when it was N/A
    YouTube - Galant GSR Hyper N/A
    then N/A with 280 cams
    YouTube - Galant GSR new exhaust stage 3 cam
    initial installation, first start with supercharger..
    YouTube - Supercharged Galant GSR (better camera)
    when it was on the dyno.. kinda boring but the sound of the S/C is louder then my exhaust...
    YouTube - Supercharged 4G63 Dyno'd
    i was honestly half way to making quad throttles before the S/C poped up on ebay..
    [​IMG]
    #12
  13. Kastigir
    Sep 22, 2008
    237
    Cincinnati, Ohio
    Can't say I like that idle with 280 cams. Good I learn these things before buying my cams. Is that a Jackson Racing SC?
    #13
  14. e85_4g63
    DSM Profiles:
    Nov 17, 2008
    1,400
    9
    Supercharger is off a Mercedes Benz. 280's don't idle like that, the video quality isn't the best.
    #14
  15. Kastigir
    Sep 22, 2008
    237
    Cincinnati, Ohio
    Well, I still don't want a pushrod V8 idle. Think I'll stick with 264/272 setup. I guess all positive displacement SCs look the same.
    #15
  16. ed_dogg23
    ed_dogg23 Proven Member
    DSM Profiles:
    Dec 17, 2006
    113
    Parker, Colorado
    Dude that is freakin sweeeet! Though i love my turbo, that sound of your ride is sick. Thanks for posting this!
    #16
  17. Kastigir
    Sep 22, 2008
    237
    Cincinnati, Ohio
    Yes, but not as bad as 280s. I'd love to hear some 272s and 264s. I guess a YouTube search is in my very near future. That car sounded like it was going to die every revolution. I'd rather not have it sounding like that. I've heard Honda B-series engines with the TODA VTEC killers...it too sounded like ass. IMO, small engines don't sound right with huge cams.
    this
    Now this sounds much better than that 280 clip. Ok, found another with the exact setup I was planning on running.
    YouTube - HKS 264/272 cams at idle
    After browsing some more YouTube clips, the 280s don't sound as bad as this Galant. Maybe being N/A has something to do with it?
    #17
  18. tunethis
    tunethis Proven Member
    Jan 29, 2008
    501
    7
    GVL, Florida
    That Galant is nice. I see you got fabricating skills. I'd like to see what kind of power you make once it's tuned perfectly.
    #18
  19. JayRome
    Dec 12, 2008
    133
    40
    Victoria, Australia
    yer sorry guys its the only way of explaining the cams, they are HKS 272 regrinds with extra lift..... way too much (well built for high RPM).... and yes thats how it sounds like in person... these cams were in an EVO1 and never sounded like this either.... and the Idle speed is at 1.1k RPM with 4-1 long extractors.. i'm currently the only one i know of in Aus that was running that set up so, not really anyone to compare with...
    but its now got VR4 cams in it, but will be upgrading back to the 272/280's (what ever the hell they are, probably in between) soon after the tune...
    basicly it was a N/A 4g63..
    balanced stock internals
    racing piston rings etc
    crank scraper
    no balancers
    stock H/G
    ARP studs all round
    head shaved to max point
    ported and polished intake side
    port matched 4-1 long extractors
    extended oil sump (1lt)
    and a few other things i cant remember...
    i havent found a 4G that sounds like mine yet...
    edit:
    this is what the car looks like..
    [​IMG]
    #19
  20. GPTourer
    GPTourer Proven Member
    DSM Profiles:
    Aug 29, 2002
    741
    3
    Birmingham, Alabama
    Okay, wait. Did you say you are running 11:1 compression with the SC? Could that not be your problem right there? Shouldn't you drop down to something more manageable like 9.0:1 or less to stop the detonation?
    #20
  21. delta448
    delta448 DSM Wiseman
    DSM Profiles:
    Jan 13, 2006
    2,779
    63
    Waynesburg, Pennsylvania
    I think the stock ignition timing is definitely the issue for you. The high compression plus instant boost is probably pushing off the top of the map at idle and low rpms where the ECU is targeting an aggressive timing curve. Especially if you punch the throttle quickly. Adding airflow/fuel with the SAFC might help bring the timing back down a little but I think you really need a standalone (or DSMLink) and a dyno tune for as much of a change in parameters as you're getting into.
    You might want to get in touch with RayPeters. He has done the supercharger (but he fed it with output from an 18G for a twincharged setup) and he's also done the 6G72tt in a DSM swap. It's strangely similar the way you two think.
    His first twincharged setup here, and version 2 here.
    #21
  22. JayRome
    Dec 12, 2008
    133
    40
    Victoria, Australia
    now thats no fun.....
    correct on the first part.... but its currently the only ECU that will run it.. and with good fuel economy too... really suprising though that is doesnt ping as much as it really should... around 10-15% throttle at very light load it pings but back off or step on the gass it goes away... so it should only be a little bit of tweeking here and there....
    yes the timing is MAXED out on negative so cant go any further.. but when put back to normal, it freakin PULLS! but pings more too and not safe....
    i was looking into a Microtech LT8 or 10, i'm just waiting for someone to sell there 2nd hand one..
    i'l get the ECU ready for the Eprom and then take it from there...
    speaking of the TwinCharge... that was already on the cards while i was building the S/C kit... i built a Turbo kit at the same time using a EVO7 RS Titainium Wheel Turbo but it ended up on my Cordia project...
    [​IMG]
    [​IMG]
    [​IMG]
    i'm starting to sway to the 6g72 cause it will just scare the shizen out of everyone... sounds like fun to..
    thanks for everyones input! :)
    #22
  23. JayRome
    Dec 12, 2008
    133
    40
    Victoria, Australia
    old thread but....
    warning to all putting Superchargers onto 4g63's....
    clip the RPM red line to around 7.5rpm.... or get a bigger s/c
    8Krpm and above + Eaton M45 supercharger = dead supercharger LOL....
    i found out the expensive way.....
    #23
  24. xreaction122
    Oct 28, 2007
    227
    Albany, New_York
    we want details!
    #24
  25. JayRome
    Dec 12, 2008
    133
    40
    Victoria, Australia
    what details would you like?
    #25
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
