1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
//STRICTLY 4G63 Engine Packages
Posted by STRICTLY, Aug 28, 2017
Please Support Boostin Performance
  1. STRICTLY
    STRICTLY Supporting Vendor
    21
    75
    Joined Feb 18, 2010
    Kalamazoo, Michigan
    //STRICTLY is proud to offer our series of 4G63 Engine Packages for your Mitsubishi!
    We offer several options for Cylinder Heads and Short Blocks, as well as totally inclusive, drop-in ready Long Blocks.
    Don't forget to contact us for your installation and tuning needs...
    If you buy an engine from us, and we install it and we tune it- WE will stand behind it.
    Yes, you read that right, an ENGINE that comes with a WARRANTY!!!
    //LONG BLOCKS
    Our Long Block packages deliver a fully built, timed, essentially plug-and-play, drop-in ready engine. Our 4G63T Long Blocks can be built to fit your power goals perfectly, from OEM+ Spec to 1,000hp+ Applications.
    //OEM+ Long Block - $2,999.99
    (OEM+ Spec Rebuild)
    http://strictlyperformance.parts/shop/all/engines-heads/long-blocks/strictly-oem-rebuilt-long-block-1g-2g-dsm-evo-8-9-engine
    //STAGE 1 Long Block - $4,799.99
    (600HP Capable)
    http://strictlyperformance.parts/shop/all/engines-heads/long-blocks/strictly-stage-1-long-block
    //STAGE 2 Long Block - $5,999.00
    (700HP+ Capable)
    http://strictlyperformance.parts/shop/all/engines-heads/long-blocks/strictly-stage-2-long-block
    //STROKER 2.3L Long Block - $4,999.99
    (Build to Order, 9k RPM+)
    http://strictlyperformance.parts/shop/all/engines-heads/long-blocks/strictly-2-3l-stroker-short-block
    //STAGE X Long Block - $8,999.99
    (1,000HP+ Capable)
    http://strictlyperformance.parts/shop/all/engines-heads/long-blocks/strictly-extreme-long-block
    *Call for custom build orders / colors options.*
    **All listed prices reflect base starting price with no extra options AND your engine core provided to us.**
    Our tune on a nearly identical build as our 2.3L Stroker w/ 6466 on E85
    Our Stage 2 Long Block 2.0L making nearly 700HP on our AWD Mustang Dyno
    //SHORT BLOCKS
    Our Short Blocks offer an affordable, substantial bottom-end engine upgrade to hold much higher power levels over the factory Mitsubishi Block.
    //OEM+ Short Block - $1,499.00
    (OEM+ Spec Rebuild)
    http://strictlyperformance.parts/shop/all/engines-heads/short-blocks/strictly-oem-rebuilt-short-block
    //STAGE 1 Short Block - $2,299.99
    (600HP Capable)
    http://strictlyperformance.parts/shop/all/engines-heads/short-blocks/strictly-stage-1-short-block
    //STAGE 2 Short Block - $2,999.99
    (700HP+ Capable)
    http://strictlyperformance.parts/shop/all/engines-heads/short-blocks/strictly-stage-2-short-block
    //STROKER 2.3L Short Block - $2,899.99
    (600HP+ Capable, Stroke/Balance Options Available, 9k+ RPM)
    http://strictlyperformance.parts/shop/all/engines-heads/short-blocks/strictly-2-3l-stroker-short-block
    //STAGE X Short Block - $3,999.99
    (1,000HP+ Capable)
    http://strictlyperformance.parts/shop/all/engines-heads/short-blocks/strictly-extreme-short-block
    //PERFORMANCE CYLINDER HEADS
    //OEM+ Cylinder Head - $550.00
    (OEM+ Spec Rebuild)
    http://strictlyperformance.parts/shop/all/engines-heads/heads/strictly-4g63-cylinder-head-stock-rebuild
    //STAGE 1 Cylinder Head - $765.00
    (Up to 274 Dur. / 800HP Capable)
    http://strictlyperformance.parts/shop/all/engines-heads/heads/strictly-4g63-cylinder-head-stage-1
    //STAGE 2 Cylinder Head - $1,100.00
    (1,000HP+ Capable)
    http://strictlyperformance.parts/shop/all/engines-heads/heads/stage-2-cylinder-head
    //STAGE X Cylinder Head - $2,499.99
    (1,000HP+ Capable, Highest Cylinder Pressure)
    http://strictlyperformance.parts/shop/all/engines-heads/heads/strictlys-extreme-cylinder-head
    **All listed prices reflect base starting price with no extra options AND your head core provided to us.**
    Q: What do we have to offer the DSM / EVO community you may ask?
    A: We are in the industry to build and offer AFFORDABLE SOLUTIONS to all of our customers that are wanting the same QUALITY and RELIABILITY that other larger companies offer.
    Q: What is your Engine Program all about?
    A: Having dealt with a very large variety of platforms and customers we have been able to come up with an ENGINE / BUILD PAYMENT PLAN available to any and all customers, regardless of platform; and works as follows:
    1. Customer states their goals with the car.
    2. An agreed upon invoice is reached with both parties satisfied with invoice total.
    3. A small deposit, usually enough to cover parts, is paid up front or when the agreed build will start
    4. Customer then has the opportunity to pay down the remaining invoice within an agreed upon time frame and or build completion date.
    Customer may also call in and make as little or large of payment they would like while the build is taking place to lower the end remaining amount.
    For more information and parts, please feel free to give us a call, email and/or check out our website.
    Thanks for reading!
    Strictly Performance Motorsports
    269-350-9055 | Sales@StrictlyPerformance.Parts
    Log in/Register to remove ads
  2. STRICTLY
    21
    75
    Joined Feb 18, 2010
    Kalamazoo, Michigan
    During this past week's dyno session, we had one of our standard-optioned 2.3L Stroker Longblocks we built throw down 477awhp with 93octane on our AWD Mustang Dyno. Here's a few pictures of its build process.
    Get in touch with us if you're in the market for a new (or rebuild yours) powerplant!
  3. STRICTLY
    21
    75
    Joined Feb 18, 2010
    Kalamazoo, Michigan
    BUMP!
    Btw, we also have this Stage 1, 7-Bolt already built, in stock and ready to ship!
    PM for more info/pricing!
  4. STRICTLY
    21
    75
    Joined Feb 18, 2010
    Kalamazoo, Michigan
    First 4G63 longblock built out of the new shop, all wrapped and getting prepped to ship! This one is an OEM+ unit.
    Call, email or PM us to get more one-on-one information for your build / goals.
Share This Page
Loading...
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Kiggly Racing Magnus Motorsports Miller Import Parts Morrison Fabrications OHM Racing Race Components Inc RockAuto Spultronix Performance STM Tuned Tire Rack VR Speed Factory White Shed Speed
