SasaniFab
- 2,433
- 782
- Dec 1, 2013
Mexico,
Connecticut
OK so I have a 1g 6bolt with about 100k on the motor. The car is completely set up tuning wise. My setup consists of a stock 6 bolt, the head had gsc s1 cams with springs and retainers, jmfab intake manifold. My fuel system is 6an front to back with a walbro 255 with pte 1000cc on dsm link (speed density). Like I said im running a fp black with a tial 40mm mvr at 20psi. I am also spraying meth with a devils own kit. The car runs great, im still working on the tune but wot my afr are in the low 11's. Im trying to play it safe and dont want to push it to far. Im aware that the stock headbolts are beefy but I keep getting told I should install arps. I guess what im asking is how much air can a stock 6 bolt handle before lifting the head or blowing a headgasket? Im at the point were If I pull the head...The motor getting built. I have arps and eagle rods sitting in boxes. If I can run 30psi with some arps safely, I might just consider the arps. What would you guys do?
