DSM B
- 43
- 11
- May 22, 2012
Minneapolis,
Minnesota
Hello All,
Build Background:
I have just completed a major front end overhaul on my 96 eclipse GSX. This included replacement of all lower ball joints, tie rods, hub and bearing assembly, poly urethane bushings, and solid subframe bushings. I have also installed adjustable Tokico Illumina with Skunk 2 coilovers and adjustable upper balljoint. I performed a front end alignment using the string method and have the toe adjusted. I have the camber adjusted pretty straight as far as my eye can see as I have lowered the car by 1.5".
Problem Statement:
My steering wheel will not return to center on it's own at any speed.
Further Information:
Since I removed the Rack and Pinion to clean it and paint it, after re-install I had to bleed the power steering system as per the Factory Service Manual. I even replaced the power steering pump with a reman unit and bleed it again after the first instance of steering wheel not returning to center.
At this point I am unsure if I have a mechanical alignment angle issue or a hydraulic assist issue not allowing it return to center. I do seem to have power steering assist as my steering wheel is easy to turn at low and no speeds, it just won't return to center on its own.
Any help, advice or input is welcome.
Thank you!
Build Background:
Problem Statement:
Thank you!
