Starting issues - No / Doesn't / Won't Start - MERGED
Posted by prodsm, Jan 25, 2004
Please Support Miller Import Parts
  1. prodsm
    prodsm Proven Member
    255
    Joined Nov 12, 2002
    canada,
    All "my car won't start" discussion threads are merged HERE. We've basically made it easier for those who insist upon not searching by grouping together all threads from those with similar issues so you can just scroll through and see some possible solutions. To search for info within this thread, use the "Search This Thread" feature in the black bar about 3" above what you're reading right now.
    Could be anything from a loose battery terminal to internal engine damage, and literally everything in between which may involve the electrical, fuel, and ignition system...possibly even something that you screwed up while working on the car yourself. While it's unlikely we're going to diagnose and solve your problem over the internet, feel free to discuss any possible solutions.
    I live in Canada and right now its not very warm out, about -30c
    my car does not have a block heater too keep it warm.
    I tryed to start my car this morning and it wouldent start, ive had this problem before but this time, the car doesnt crank at all it just makes a sound that sounds like an electric drill.
    Whats wrong.
    Thanks
    Log in/Register to remove ads
    My DSM:
    Loading...
  2. 1.8laser90
    1.8laser90 Proven Member
    337
    3
    Joined Jun 8, 2003
    alliance, Ohio
    it sounds like u need a new battery, hope this helps :thumb:
  3. brucerap
    brucerap Proven Member
    27
    Joined Nov 12, 2003
    sounds like the starter's not engaging. Try this - take a hammer and give the starter a couple of taps. Then try starting it again. If the solenoid is sticking it may free it up enough to engage.
  4. prodsm
    255
    Joined Nov 12, 2002
    canada,
    Well i brought it too a shop a Canadian Tire to be exact and they told me that the timing belt skipped a few teeth. But the thing is i replaced the belt and balancer belt not even 10,000 kms ago!
    I dont know if they're bull sh**ting me or not?
    Could there be another reason for the car not starting?
    OR
    Is it infact the Timing belts fault..
    Thanks
    My DSM:
    Loading...
  5. AKTNDR
    AKTNDR Proven Member
    10
    Joined Jan 6, 2004
    Prince George,
    I would think it is the battery, I have the same problem now it is damn cold out and even when I plug it doesn't start that great. Try and get the battery tested.
  6. vodavi6346
    vodavi6346 Proven Member
    10
    Joined Sep 18, 2004
    kissimmee, FL, Florida
    car starts fine when its cold but when its warm it won't start its 91 talon TSI fwd auto ... any one know what might be causeing it ?
  7. vodavi6346
    10
    Joined Sep 18, 2004
    [​IMG]
    what is the gold fitting sticking out of the vaulve cover .. also what is that is plugged ... the guy i got it from said all emesions is off is this emmesions stuff ?
    [​IMG]
    you see the red wire going to the harness with the little box in duck tape ? what could that be ??
    [​IMG]
    [​IMG]
    what is this and why is it unplugged ?
    I am posting this here because I dunno if these could be why or why not its not wanting to start up when warm
  8. Sil-Eighty SE-K
    Sil-Eighty SE-K Proven Member
    29
    Joined Sep 19, 2004
    Phoenix, Arizona
    i had the same problem with my sr20 twice.....each time we took it out/apart.....we forgot both times to plug in the temp sensor that went to the ECU....im not sure if the 4g63 has the same thing but i would assume it does......your may be bad or disconnected.....i believe that gold plug in the valve cover is just an emmissions thing......nothing to do with it......the other plug im not so sure of.....anyways
    Does it smell alot like fuel when u crank it?
    Mine would barely barely start cold and not at all hot unless we pulled the fuse to the fuelk pump until it kicked over then replaced it immedately....try that and see how that works...
    Mine thought the motor was frozen cold with the sensor unplugged so it would pull timing, dump assloads of gas and give a small sh**ty spark.......which is how the motor will cold startup.....so try that fuel pump fuse.....if that works for u track down that sesnor and replace it
  9. StreetSleeper34
    StreetSleeper34 Proven Member
    156
    Joined Mar 29, 2004
    Dubuque, Iowa
    "Gold Fitting" coming out of the valve cover is the PCV, it should be connected to a vacuum hose going back into the intake, which may be the one blocked off. This would have nothing to do with it starting or not, that is also an emissions thing. If you have a coil going out, this could cause it to not start in warmer weather as well.
  10. norice4me
    norice4me Proven Member
    242
    Joined Oct 10, 2003
    sewaren, New Jersey
    it is you temp sensor to the ecu i had the same prob change that and you will be fine
    My DSM:
    Loading...
  11. gsxonjackstands
    gsxonjackstands Proven Member
    16
    Joined Mar 22, 2005
    ypsilanti, Michigan
    ok if anyone canhelp me out id apprecitate it, car is 90 laser fwd replaced ecu replaced cyl head car is gettin spark fuel is gettin to fuel rail but no signal to injectors tried another ecu verified it works in another car tried another cam sensor same thing, swapped mpi fusible link, verified alll connectors in right places, swapped ignitor as well im not a newbie but this thing is gettin frustating fuel pump is engagin anhy ideas thanks in advance!..:beatentodeath:
  12. LunarEclips
    LunarEclips Proven Member
    189
    Joined Feb 27, 2006
    Corona, California
    check your timing. It's most likely off.
  13. luv2rallye
    luv2rallye DSM Wiseman
    7,285
    420
    Joined Jun 7, 2003
    Minneapolis, Minnesota
    First make sure you have +12V on one side of each injector (if not check mpi relay and fuse and injectors resistors). You will probably read +12V on both sides since the other side floats until it gets a very short pulse to ground by the ECU. [You can unplug each injector to verify the +12V is really only on one side. You can then plug it back in and touch the other side (not the +12V side) to ground (can stick a pin through the wire insulation to get at wire) to make sure the injectors work - this will also test the resistors continuity]. If ok, then check continuity from that other side of each injector connector (unplug it) to the proper pin on the ECU per the manual. If ok, then your problem must either be the ECU or devices which the ECU needs to fire injectors (eg. cam sensor, mpi relay, etc). BTW is this a turbo?
    My DSM:
    1999 Mitsubishi Eclipse GST
    14.200 @ 95.000 MPH
    Loading...
  14. LunarEclips
    189
    Joined Feb 27, 2006
    Corona, California
    He already check the mpi fuse and the connections to the fuel injectors. I dont believe its a fuel problem. I believe its more of a timing problem....
  15. luv2rallye
    7,285
    420
    Joined Jun 7, 2003
    I think so too but he's so insistant it's an injector problem that I thought I'd tell him how to test them. But most likely the ECU isn't firing the injectors because of some other problem which has priority (like timing).
    My DSM:
    14.200 @ 95.000 MPH
    Loading...
  16. greytalon26
    greytalon26 Proven Member
    92
    3
    Joined Oct 27, 2005
    Ann Arbor, Michigan
    I've been working on this laser for a while now with gsxonjackstands, and we're sure it's a fuel problem because we've replaced the ecu, cam sensor, and injectors along with trying multiple heads, and we spend a long time making sure it was timed correctly the problem is that the injectors aren't getting the signal to fire because a noid light doesn't show any signal.
    My DSM:
    Loading...
  17. greytalon26
    92
    3
    Joined Oct 27, 2005
    Ann Arbor, Michigan
    Yes.
    My DSM:
    Loading...
  18. TurboLaserDude
    TurboLaserDude Probationary Member
    4
    Joined May 24, 2006
    Chicago, Illinois
    I am having the same exact problem! I had my ecu repaired, cap replaced. Fuel pressure is within specs, I have adaquite spark i.e. poured starting fluid down the intake... started & ran for a min. had injectors tested & work properly. 12v at the injector wires, what sensor would possibly block the ecu from firing the injectors? Cam angle sensor? but my plugs are firing... I doubt i have a short, but I will check anyhow, Could anyone think of somethin I missed? thanks
  19. hypnotized24s
    hypnotized24s Probationary Member
    4
    Joined May 25, 2006
    GSO, North Carolina
    haha.. i am having the exact same problem as well.. i have a 90 laser rs n/t. im getting good spark.. plenty of fuel pressure to the fuel rail.. my injectors just arent fireing.. i just had my ecu repaired and it still wont work.. if i spray ether into my cyliners the car will start but not run. it just cuts off after it runs out of ether. i have 12+ volts at the injectors. i just got a wiring diagram for the whole ignition system.. and im pretty sure everything is wired correctly. i have no clue what to do next?
  20. toybreaker
    toybreaker Proven Member
    339
    26
    Joined Mar 24, 2006
    Never Summer Ra, Colorado
    On the 90's the cas plugs in over at the firewall.
    I've had issues with the actual harness connection where the male/female pins *should* be connected.
    I could wiggle the connector some and get a misfire, and then get it to flat die.
    Closer inspection revealed the female harness pins were slightly bent out, and the pins had some corrosion on them. I bent the pins back (gently) with a 90* pick, and then cleaned the pins with some radio shack contact cleaner/enhancer. It's been all good ever since.
    Remember, the cas has 2 trigger wheel tracks, and 2 pickups.
    One with four evenly spaced pulses, and one with 2 irregularly spaced pulses. The ecu needs to see both triggers to be able to generate the injector pulse.
    I would quadriple check the cas connector over at the firewall.
  21. missouri_dsm
    missouri_dsm Proven Member
    260
    8
    Joined Jul 27, 2003
    Lebanon, Missouri
    check your coolant sensors on the thermostat housing. If one is shot or not plugged in it could cause this.
  22. hypnotized24s
    4
    Joined May 25, 2006
    GSO, North Carolina
    why would a coolant sensor make it not send an injector pulse?
  23. missouri_dsm
    260
    8
    Joined Jul 27, 2003
    Lebanon, Missouri
    I had no spark once and I hooked up a noid light and had nothing. I found a coolant sensor was unplugged and plugged it in and all of a sudden I had spark. Coincidence....maybe. Worth a shot.....definately.
  24. hypnotized24s
    4
    Joined May 25, 2006
    GSO, North Carolina
    anything is worth a try about now.. i just am not gettin an injector pulse, i am getting a pulse from the CAS to the processor chip in the ecu. and i even jumped power to my injectors and they fire, and even have fuel. something is either wrong with my ecu or somethings not letting my ecu create an injector pulse, what would stop my injectors?
  25. PSI NRG
    PSI NRG Proven Member
    207
    5
    Joined Nov 2, 2004
    Solon, Ohio
    Theres a connection for the injectors that the harness is connected to should be on the driver side. This is what all the injectors tie into check that cause I had the same problem the car would turn over and spark but just no fuel. Plugged it back in and taped it so it wouldnt come loose and its been fine ever since.
    My DSM:
    Loading...
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
