Starter not catching the flywheel
Posted by DSMRyan, Jun 10, 2005
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support Feal Suspension
  1. DSMRyan
    DSMRyan Proven Member
    May 20, 2005
    33
    Lacrosse, Wisconsin
    The previous owner could never get his starter to work, so we thought it might just need a new one. Well after taking it out, it was fine and after we put it back in we noticed the noes of the starter isn't catching the flywheel so my car won't start. Anyone know what the problem might be? The parts all are from the same model so that can't be the problem. Thanks.
    #1
  2. wret
    wret Proven Member
    Jul 3, 2003
    2,695
    52
    Bel Air, Maryland
    Sounds like the bendix is not engaging.
    #2
  3. DSMRyan
    May 20, 2005
    33
    Lacrosse, Wisconsin
    Thanks but I tried and the entire starter is working. I think the previous owner put the flywheel on backwards so I'm taking the tranny out tomorrow and switching it around. Hopefully this fixes it. :notgood:
    #3
  4. fwdturbobov1996
    fwdturbobov1996 Proven Member
    Feb 27, 2004
    559
    7
    Blue Springs, Missouri
    wehres the starter located? .LOL. and how hard is it to disconnect from the flywheel
    #4
  5. DSMcrazy3
    DSMcrazy3 N/T DSM Wiseman
    DSM Profiles:
    Dec 29, 2004
    1,843
    59
    Humble, Texas
    I dunno bout location on 1g's but on 2g's it right in front(irrelivant) but to disconnect, all you do is disconnect the battery and wires, unbolt, and pull away. the starter only touches the flywheel upon start up, for a second max, just to get it goin.
    #5
  6. DSMRyan
    May 20, 2005
    33
    Lacrosse, Wisconsin
    Well I really can't get to the flywheel without pulling the tranny out it seems, even when the car is hoisted it's hard to get to. Has anyone done it in a 1g without taking the tranny out? It'd save me some time.
    #6
  7. Defiant
    Defiant DSM Wiseman
    DSM Profiles:
    Jan 13, 2003
    25,202
    117
    glorious Galt, California
    Okay, ready now for the rest of the story. What all swapping had been done? Sounds like you have the wrong flywheel.
    #7
  8. wolf20043
    wolf20043 Proven Member
    Mar 13, 2005
    861
    38
    pueblo, Colorado
    You cant get around not pulling the tranny to get to the flywheel.
    Mike
    #8
  9. blueberry_dsm
    blueberry_dsm Proven Member
    Jan 23, 2005
    92
    Racine, Wisconsin
    i would have to say u might have the wrong flywheel. but chances are, because this happened to me, is the fact that the starter might be from the other type of transmission. i cant remember which is which, but one either auto or 5-speed, the nose on the starter is shorter, and on the other it is longer. i could see this happening if the starter in there was from the junkyard, otherwise im not sure, but check the flywheel, and also check to make sure the starter you have in there is also for the correct tranny.
    #9
  10. DSMRyan
    May 20, 2005
    33
    Lacrosse, Wisconsin
    Well after taking the tranny out today the back plate that sits behind the flywheel is all bent up. So I'm thinking this is what is stopping the starter from hitting the flywheel. I'm going to try to bend it back or cut some away. Then again, you may be right about the starter being wrong and not being long enough. I guess I'll find out tomorrow.
    EDIT: What is the real name for the "shield" or "plate" that sits behind the flywheel?
    #10
  11. blueberry_dsm
    Jan 23, 2005
    92
    Racine, Wisconsin
    also the 91 is year specific, it has a smaller flywheel than the rest. thats why u need a clutch specific for a 91 and a starter specific for a 91 as well
    #11
  12. 98evoIIIpwr
    98evoIIIpwr Proven Member
    Jan 29, 2005
    287
    3
    Moreno Valley, California
    Well my guess is that its the plate. I had the same problem when swapping an evoIII motor into my car. Because the AWD and FWD plates are different they make the starter sit in a different spot. After changing the plate my starter engaged just fine. Like he said above, were any swaps done? If so then I can almost guarantee that the plate is wrong, or like you said bent up too bad. :dsm: not sure what the actual name for the plate is but i think its rear plate... ;)
    #12
  13. blueberry_dsm
    Jan 23, 2005
    92
    Racine, Wisconsin
    i would almost guarantee that the plate has nothin to do with it. i would suggest goin to checkers (thats where i got mine from) and bringing your starter with you, and compare your current starter to a new one of the correct tranny and compare the noses. i would almost guarantee that the new one will have a longer nose.
    its possible that the previous owner may have done a tranny conversion, not knowing that the starter is different. huh idk, but go compare that starter to a new one and see if the nose is different. :thumb:
    shane :dsm:
    #13
  14. DSMRyan
    May 20, 2005
    33
    Lacrosse, Wisconsin
    Thanks a lot everyone, all of those are definite possibilities. Does anyone know the actual length of the starter for the 91 talon non-turbo 5 speed? I have mine sitting right next to me and the entire thing is 8 inches. The nose itself is about 2 1/2.
    The previous owner swapped the tranmision for a 90, or 91. So if it was a 90, then I would have to get a different flywheel and starter, or a 91 transmissoin, right? Could someone give me some insight please! :|
    #14
  15. BISHILVR
    BISHILVR Banned Member
    Nov 14, 2003
    1,152
    13
    salem, Ohio
  16. blueberry_dsm
    Jan 23, 2005
    92
    Racine, Wisconsin
    yup, i thought that was it. let me kow how this goes.
    shane :dsm:
    #16
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
