krummel21
- 497
- 1
- May 4, 2004
Charles City,
Iowa
I can here and feel the vibration of the starter hitting the flywheel but it won't start the car. I checked the voltage at the main wire and it sees the same that the battery is putting out (12.4 volts). I also checked the black/yellow wire and it is not showing any voltage with the key off.
What else would cause this problem?
The starter and battery are new. My next check is to see if the relay is bad.
I unbolted the plate from under the dash that I think the relay should be attached to which one is the relay?
