1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
Starter grinding horribly
Posted by BLOHS7844, Aug 19, 2012
Please Support ExtremePSI
  1. BLOHS7844
    BLOHS7844 Proven Member
    287
    Joined Oct 25, 2011
    Appleton, Wisconsin
    So I had some machining done to my head and had my car down for a bit. I went to start it and was grinding terribly. Starter bolts were a little loose but I took my starter out and the teeth looked fine and I tested it which killed it in the process (don't ask) :ohdamn:
    Replaced the starter and it was fine for maybe 10 seconds of cranking overall. (not 10 seconds all at once) and the started grinding a little too. I pushed in the clutch and that actually seemed to help for a second but it got just as bad as before. I had someone listen at it was definitely coming from the starter area.
    I am only missing 1 transmission bolt and I just put a new one in but it was very hard to get it in. Its the bolt thats the second to the right of the starter. (Right under the oil feed for turbo) Using torque wrench I could only turn it with greater than 50ft/lbs of force but it was also less than 100.
    My flywheel, which I think is oem but I have no idea if it was replaced at all, looked to be fine (through the inspection plate. I don't know exactly what a normal one would look like as far as the angle of the teeth. It looks kinda rusty. Definitely was rusty colored but it looked structurally sound.
    Any thoughts?
    EDIT: When I cranked in 5th gear the tire did move so the flywheel is moving when cranked. And I can turn the engine with the crank pulley just fine
    Log in/Register to remove ads
    My DSM:
    Loading...
    Featured Products from our Supporting Vendors
  2. 3kgt2nv
    3kgt2nv Proven Member
    1,342
    13
    Joined Jan 7, 2011
    poughkeepsie, New York
    with the missing flywheel bolt you most likely tweaked the alignment slightly by cranking it and thats why it was so hard to get in. Also did you use the correct flywheel bolt length?
    as far as the second starter dying so fast was it brand new or a used piece?
  3. BLOHS7844
    287
    Joined Oct 25, 2011
    Appleton, Wisconsin
    Not missing a flywheel bolt. its a transmission bolt and it was the right length.
    Second starter didn't die at all.
    My DSM:
    Loading...
  4. 3kgt2nv
    1,342
    13
    Joined Jan 7, 2011
    woops reading comprehension fail. LOL
    with the second starter does it seem like its having a hard time turning the flywheel or is it just grinding like its not engaging properly. also make sure you attached the positive battery lead to the correct post and the ground wire is hooked up to the tranny bolt in the stock location.
  5. BLOHS7844
    287
    Joined Oct 25, 2011
    Appleton, Wisconsin
    No electrical problems at all. Just a huge grinding
    My DSM:
    Loading...
  6. Jose303
    Jose303 Probationary Member
    17
    Joined Feb 26, 2013
    Denver, Colorado
    Did you ever fix this?
    Im having the same problem and need some help.
    My DSM:
    Loading...
  7. northernawd
    northernawd Proven Member
    233
    3
    Joined Jun 23, 2012
    yellowknife, NT, YK, Canada
    which problem? the grinding or starters dying
  8. Jose303
    17
    Joined Feb 26, 2013
    Denver, Colorado
    Im having the grinding been researhing for days but no solutions.
    My DSM:
    Loading...
  9. BLOHS7844
    287
    Joined Oct 25, 2011
    Appleton, Wisconsin
    its been sitting for a while till I get more money LOL you are going to have to explain whats happening with your starter
    My DSM:
    Loading...
  10. killercolt
    killercolt Proven Member
    294
    18
    Joined May 23, 2008
    Acworth, Georgia
    Check the followings if you have starter grind
    Check Flywheel. Awd flywheel has a smaller ring gear diameter than fwd. if you have a Gst, you can accidently put in an Awd flywheel
    Check to make sure start is tighten on the bell housing.
    Make sure the tranny is flush against the block. Make sure the front lower bolt and rear lower bolts are tighten. At least one of the top bolt is on there.
    Take the starter out and check it. Some aftermarket starter comes poorly assembled. Take the starter out and check the two skinny bolts that hold the started together.
  11. Jose303
    17
    Joined Feb 26, 2013
    Denver, Colorado
    I was getting a horrible grinding sound every time i cranked my car its an automatic 96 GST. The grinding started after i took the starter off to change my intake manifold gasket. When i put it back together i got this horrible grinding noise. The grinding got so bad that my buddie was standing outside and he saw sparks coming out from around the starter. After this i stopped cranking the car. My next step was to turn the engine over manually to see if i could hear any strange noise sure enough didnt hear anything. I decided to take the starter off and bench test it it seemed fine. I still bought a re-manufactured one because it seemed it was sticking a little. Tried it back on still grinding. Changed the terminals because they where a bit loose thought i wasnt getting enough power but didnt help. I inspected the flywheel no major damage just looks a little worn but from the grinding thats going on but like i said nothing too bad.
    My DSM:
    Loading...
  12. Fast95GSX
    Fast95GSX Proven Member
    63
    Joined Feb 25, 2011
    Grand Rapids, Michigan
    jose303 did you figure this out?
  13. turbotalon1g
    turbotalon1g Proven Member
    801
    30
    Joined Oct 19, 2005
    Blaine, Minnesota
    X2
    My DSM:
    1991 Eagle Talon TSi AWD
    Drag Race Build
    11.333 @ 119.94 MPH
    Loading...
  14. fredyvalles1995
    fredyvalles1995 Proven Member
    37
    Joined Sep 30, 2013
    Dallas, Texas
    I had the same problem when I bought my 2g eclipse I had more problems than I think you do but make sure everything is there and thight.i pulled the transmission and found out I was missing the starter plate,two transmission bolts,and the two dowel pins.that solved my problem.
  15. Changoloco402
    Changoloco402 Probationary Member
    5
    Joined Oct 2, 2018
    Omaha, Nebraska
    Anybody ever figure it out I also have the same problem I've changed the starter as well ran good no noise for couple days then happened again not sure why. If it were to be the wrong starter plate wouldn't it have made the noise from the start?
    My DSM:
    1995 Eagle Talon TSi AWD
    Street Build
    20g   manual
    Loading...
  16. motomattx
    motomattx Proven Member
    1,076
    220
    Joined Dec 9, 2010
    wampum, Pennsylvania
    You probably dont have the starter sitting square in the hole, its likely leaning to one side because its either stuck on the transmission shim or it got tightened down wrong somehow, unless you bought a new starter, in that case its likely the wrong starter.
    My DSM:
    1995 Mitsubishi Eclipse GST
    Drag Race Build
    GT42   manual
    Loading...
    Changoloco402 likes this.
  17. Changoloco402
    5
    Joined Oct 2, 2018
    Omaha, Nebraska
    Gotcha alright I'll make sure its square on there when tightening the starter back on
    My DSM:
    Street Build
    20g   manual
    Loading...
Share This Page
Loading...
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
