Psychos1s
- 72
- 0
- Jun 3, 2009
Albany,
Oregon
I went to English Racing yesterday to get my stock air meter removed with the Speed Density conversion. I figured I would share the results for those that are considering it or wanted more proof of the 2g MAF limitations. All my results are on pump gas. Until my car retires from daily driver status, I want to continue to run on 92 octane.
Before the SD I was consistently putting down high 330s (339whp, 337 ) at 26psi. 339whp being my top mark. For everyday use the boost was turned down to 24psi and was running in the 320s (326whp if I remember correctly).
After the SD conversion with a custom intake I was putting down consistent high 340s to low 350s at 26psi. I was hoping for 350 and got right there. My final output was 354whp while my torque stayed basically the same at 336-337 lb-ft. (At 24psi Im at my old number 338whp)
So an increase of 15whp uncorrected (354whp vs 339whp). Its actually at 19whp corrected (352whp vs 333whp). Not too shabby
The mods:
The dyno sheet shows the best of both runs before and after the SD conversion
The mods:
- Stock 6 bolt (2g head), 3g lifters, ARP headstuds
- Stock intake & exhaust manifolds
- ECMLink v3
- Walbro 255 fuel pump
- Evo Injectors (560s)
- Apexi GT downpipe & N1 exhaust
- Evo III 16g
- FP2 cams
- ETS 10.5 Racing Intercooler
- Greddy Type RS BOV, AEM TrueBoost Boost Controller
