DsmDanielson
- 104
- 0
- Jul 13, 2016
Peoria,
Arizona
as the title states,I’m doing a transmission and clutch swap on my 1997 Gst. I got a competition clutch, new transmission, oem throwout bearing, etc. I used to alignment tool to put on the clutch and the clutch bolted in perfect with no problems. I put on the transmission after grabbing 3 friends and after a couple hearnias, we found finally got the transmission in place. I heard a thunk and I knew the splines had to have matched up and I bolted it up. Now to check the fitment, I pushed in the clutch fork to simulate the action and the throw out bearing doesn’t even touch the pressure plate until the fork is Towards the passenger side, and when it is touching I can’t get the pressure plate to disengage the clutch at all it’s like pushing a brick wall when I press on the fork. What gives?
