AeroForceDSM
- 0
- Aug 15, 2014
Elyria,
Ohio
I have been doing alot of reading, I have a 14b on my car, literally every bolt on I can possibly have, but with a stock side mount and 450's. I am running 21psi and my afr is 11.8, from my research... the injectors shoukdnt be keeping up. My question is... when I put my fmic on, and it cools the air better, will it lean out and then the 450's wont be enough? Is the charge getting so hot, the psi is there but the flow in cfm is not due to the air being so hot and thats how the 450s are keeping up. I have 650s to put in it but i havent because it just dont need them. my best ET is 14.003 @ 103, and it should be faster. the only things left are fmic, and injectors. I have megan 3" turbo back, act 2600 clutch, walbro 255, braided feed, and return, safc, hard pipes, mbc, aeromotive regulator, catch can, motor mounts, 1g bov...
