Please Support Kiggly Racing
2G 12V Power on motor, shorting
DSM Chase
778
51
Sep 19, 2011
Senoia, Georgia
Anything that touches my head or intake manifold and then touches the chassis gets power and starts shorting, the intake manifold ground sparks and pops and usually blows the alternator fuse if kept on too long, don't have any cut wires and my harness is not hacked up...WTF
If you complete a path from the chassis anywhere to the head or intake Mani, it sparks and shorts like there is power on the motor. The throttle cable if you try to hook it up to the throttle body it sparks and shit, anything metal that completes a path from it to the chassis sparks.
Yea you've somehow(???) got 12v on your intake. Also head and block. They all are connected. You've got a ground wire hooked up to the positive.
Unhook the power wire from the alternator and the battery. Now do a continuity to ground test on the wire. If there is no continuity than like stated above you probably have an internal short to ground in the alternator.
Im more than positive you don't have the boot that covers the positive wire going to the starter and when you tightened it you made the wire hit the solenoid thus shorting out thru there. I had the same issue back then and same thing anything I would ground on the motor would short.
I think that's it I tore that boot, but it doesn't seem to be touching anything, I'll throw another boot on and try that! Makes sense as to why there's so much power on head and intake mani, the alternator was good when I pulled the motor out so I figure its Still good LOL, I'll check all this this afternoon.
It should fix your problem bro. So did you ever find out why you had problems when installing the 6bolt? I remember your Instagram post
Continuity to ground would consist of the multimeter positive on the alternator wire while off alt, then the negative on multi to the chassis?
Yes with the multimeter set to continuity or just resistance (ohms) if there is no continuity setting.
"You must have the small plastic piece which separates the alternator casing from the internal bolt to prevent grounding out the system and blowing the fuse"...
Does the plastic separate the stud nut that screws into the alternator, or is the plastic to separate the 12V wire terminal that goes on it from the alternator body? Confusing
None of that worked, starter wire is good. Still only does it when alternator 12V terminal is on.N[DOUBLEPOST=1409691670][/DOUBLEPOST] Tried to spin it over with the battery charger on charge for the hell of it with alt disconnected, now the starter clicks really fast and loud and doesn't spin over, Everything still shorting out if it touches motor if the alternator 12v is on. I don't understand all these electrical components worked a week ago.
So you didn't have continuity to ground with the alternator wire, but you are grounding out with the wire hooked to the alternator. IF that is the case than the alternator is grounding internally. It would need to be replaced if this is the case. Go have it tested.
