1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
1G Shifter cables stiff?
Posted by RipperXX, Sep 15, 2018
Please Support Southbay Fuel Injectors
  1. RipperXX
    RipperXX Proven Member
    3,133
    113
    Joined Feb 23, 2003
    Royston, Georgia
    I noticed about a month ago my shifter seemed a little stiff and it's only gotten worse. It doesn't want to move freely on the horizontal (left to right) it wont return to center like it ought to on it's own either. Any idea what the most likely cause is? Rather where to start investigating? Around spring I replaced the plastic bushings that time had caused to disintegrate it's been fine until recently. So I think it's the cables?
    Log in/Register to remove ads
    My DSM:
    1990 Eagle Talon TSi AWD
    Street Build
    13.476 @ 105.48 MPH
    Loading...
    Featured Products from our Supporting Vendors
  2. RipperXX
    3,133
    113
    Joined Feb 23, 2003
    Royston, Georgia
    Anyone? I ask because I don't have much time right now with 3 kids who are all in soccer etc. plus chores. Anyone know a likely cause? Bushings? Is there some spring? can cables be lubed? If so, what's the best way?
    My DSM:
    Street Build
    13.476 @ 105.48 MPH
    Loading...
  3. amsrn13
    amsrn13 Proven Member
    1,892
    467
    Joined Dec 1, 2013
    danbury, Connecticut
    So you already replaced the bushing and lubricated the shifter assembly. You also have it adjusted correctly? Do you have an aftermarket Intake manifold....ive noticed that certain manifolds sit the throttle body so low it hits the cables and makes shifting more difficult.
    My DSM:
    1992 Eagle Talon TSi
    Street Build
    645 whp   498 lb/ft
    Loading...
  4. luv2rallye
    luv2rallye DSM Wiseman
    7,402
    477
    Joined Jun 7, 2003
    Minneapolis, Minnesota
    My DSM:
    1999 Mitsubishi Eclipse GST
    14.200 @ 95.000 MPH
    Loading...
  5. brian9397gsx
    brian9397gsx Proven Member
    1,066
    72
    Joined Apr 28, 2008
    sioux city, Iowa
    I've also had the cables themselves be bad that made them really stiff like your saying. Disconnect them from the shifter and trans then check your shifter. Then check the cables. I had to buy new cables from Mitsubishi, bring lube it hurt.
    My DSM:
    brian9397gsx 1993 Mitsubishi Eclipse GSX
    19.80 @ 35.55 MPH
    Loading...
  6. RipperXX
    3,133
    113
    Joined Feb 23, 2003
    Royston, Georgia
    Thx, I'll pull it into the shop this weekend and see how the lever assembly looks and see how the cables move with them disconnected from the transmission.
    Also, no aftermarket intake manifold.
    My DSM:
    Street Build
    13.476 @ 105.48 MPH
    Loading...
  7. agentorange313
    agentorange313 Supporting VIP
    1,813
    49
    Joined Dec 21, 2008
    Westfield, New Jersey
    unfortunately 1g shifter cables are no longer available from Mitsu
    My DSM:
    1991 Eagle Talon TSi AWD
    10.455 @ 104.000 MPH
    Loading...
  8. DSSA
    DSSA Supporting Vendor
    278
    59
    Joined Jul 26, 2002
    Hatfield, Pennsylvania
    ^^^^ This. The lever bolted to the transmission has been known to almost seize at the pivot point and cause this.
    You don't have anything like skateboard bearings in the ends of the cable do you? If so, these often seize up as well unless you keep them regularly lubricated. I've also seen the bronze units seize as well (the steel pivot point on the levers rusts and causes everything to bind), which is why we made and have always used the Delrin units, as they're sacrificial to the metal.
    tk106 likes this.
  9. tk106
    tk106 Proven Member
    646
    70
    Joined Sep 11, 2017
    Cincinnati, Ohio
    +1 DSSA
    Most likely the lever assembly on the trans. Clean and lube should fix it.
    My DSM:
    1992 Eagle Talon TSi AWD
    Street Build
    16g   manual
    Loading...
  10. tk106
    tk106 Proven Member
    646
    70
    Joined Sep 11, 2017
    Cincinnati, Ohio
    Disconnect the cables from the shifter assembly inside the car and see if it’s still tight. That’ll point you in the right direction
    My DSM:
    Street Build
    16g   manual
    Loading...
  11. RamenPride
    RamenPride Proven Member
    2,289
    55
    Joined Aug 18, 2002
    Virginia Beach, Virginia
    A couple years ago I was having issues shifting, especially 2nd to 3rd and 4th to 5th. It was so bad that I as thought the tranny needed a rebuild. Turns out coolant had leaked onto the lever(s) below, mixed with the lube creating a thick pasty substance and dried. Cleaned it up and lubed everything, and it's shifting better than it has in years.
    My DSM:
    Loading...
    Ohmega and RipperXX like this.
  12. RipperXX
    3,133
    113
    Joined Feb 23, 2003
    Royston, Georgia
    ,,I found a coolant leak that had been dripping from a short connector on my home made coolant over flow can that seems to have been doing exactly this! Thanks for posting! I'll update soon if it was in fact the case here.
    My DSM:
    Street Build
    13.476 @ 105.48 MPH
    Loading...
    DSSA likes this.
Share This Page
Loading...
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
