larryd
- 4,553
- 0
- Nov 26, 2001
Bear,
Delaware
How do you set the base ignition timing on a 2nd gen that has a 6 bolt block with a 1st gen adjustable CAS. I know on the 1st gen you have a wire that you can ground and it stops the timing from jumping all over the place at idle but since the 2g wasnt meant to have adjustable base ignition timing there is no such wire. Also what should the base ignition timing on a 2g be set at?
I have a feeling that my base igntion timing is off pretty bad and thats why my timing on the car is soo horrible because its already to far advanced.
