Barney Dsm
- 42
- 1
- May 25, 2016
Westland,
Michigan
In the process for building a custom sequential shifter for a 1g awd stick. Seems like the other options are to spend some serious coin which is bull
Note: This feature currently requires accessing the site using the built-in Safari browser.
I'm actually working on this too are you planning on selling it?Guess people really want these huh ?
Sequential is the shifter. its nothing to do with inside the transmission.Can you make a real sequential selector inside the transmission? like what MTI racing made for corvettes. http://www.corvetteforum.com/forums...equential-transmission-conversion-system.html
full benefit can't be realize if you make shifter that can only move up or down. It still defeat the purpose of shifting quickly. Ikeya formula shifter are over priced and only mimic what real sequential transmission does.
Id like you to post updates on that. Is it going to be mechanical or hydraulic?Exactly it's more fun and different ! And if you could do it for cheap (less than 100) out of pocket why not!
Mechanical and probably a bit over $100Id like you to post updates on that. Is it going to be mechanical or hydraulic?
