1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
Rust Removal
Posted by Mitsubishiown, Aug 10, 2018
Please Support ExtremePSI
  1. Mitsubishiown
    Mitsubishiown Proven Member
    131
    10
    Joined Feb 11, 2012
    Davison, Michigan
    Today was a pretty disappointing day and still pretty upset by the discovery today but just going to have to learn how to do some body work. Luckily there is a ton of information on this subject and the info doesn’t really have to be car specific although I now have found a couple well documented rust removals from this forum. Going to use this to catalog the long process. If anyone has tips let me know! I was aware of rust but didn’t think the pinch welds were nearly as bad as they were and they collapsed when being jacked up. Also removed the side skirt to find it was eaten through on the drivers side, haven’t checked passenger side yet. So I believe my plan is going to be to go through it with a wire brush to see what’s salvageable and whatever isn’t I will cut out and attempt to weld in new sheet metal for the rear wheel well area. Not sure what to do with the pinch weld yet. Here are some pics.
    2BEA4CE7-F0B3-4DD4-A867-0445B320129A.jpeg 046C6FD3-6D02-4CB1-9195-0921883B2061.jpeg
    Log in/Register to remove ads
    1997 Mitsubishi Eclipse GSX
    Drag Race Build
      automatic
    Loading...
    Featured Products from our Supporting Vendors
  2. motomattx
    motomattx Proven Member
    1,156
    245
    Joined Dec 9, 2010
    wampum, Pennsylvania
    Someone in Michigan on the parts trader was selling a stripped out 2g shell for $50 you might want to look into it, I didnt see any apparent rust on it.
    1995 Mitsubishi Eclipse GST
    Drag Race Build
    GT42   manual
    Loading...
  3. Mitsubishiown
    131
    10
    Joined Feb 11, 2012
    Davison, Michigan
    Okay thank you I will take a look at it for sure!
    Drag Race Build
      automatic
    Loading...
  4. Mitsubishiown
    131
    10
    Joined Feb 11, 2012
    Davison, Michigan
    92270FE8-C576-4F7C-9E7D-7651133A9FAD.jpeg 6ED91B19-D278-43D6-A155-630485C59167.jpeg 33802FAB-56BC-4396-B077-7B00CBD91F65.jpeg F23F6F7A-726B-43F5-8932-0D7F5D65A3D3.jpeg 7BB1D70E-4322-4F0B-9A87-8151F353A56C.jpeg So no clue what I’m doing really but went and bought a course wheel to remove paint and rust and went to town and once again much worse than I thought. Trying to stay positive though, it’s now turning into a learning opportunity to learn how to take care of rust properly and do some body work. With that said not really sure what to do about the pinch welds being bad or the wheel well. I’m thinking find one at a scrap yard with little rust and cut out the wheel well and side skirt area as well as the pinch weld and then weld it back in?
    Drag Race Build
      automatic
    Loading...
  5. pksystems
    pksystems Proven Member
    185
    107
    Joined Nov 9, 2003
    Calgary, AB, Canada
    Brings back memories. I have repair pics in my build thread if you want inspiration, altho mine was no where near that bad.
    The good news is side skirts will completely hide the repair, so the repair doesn't need to look perfect.
    Loading...
    Mitsubishiown likes this.
  6. Jamesberry2382
    Jamesberry2382 Probationary Member
    8
    3
    Joined Jul 21, 2018
    Griffith, Indiana
    [​IMG] [​IMG]
    Man do I hate rust
    Loading...
  7. Mitsubishiown
    131
    10
    Joined Feb 11, 2012
    Davison, Michigan
    Yeah it’ll be an interesting process for me. Took out the seats and carpet today to make sure the floor pan is fine and there’s just a little rust on some bracket thing on the drivers side floor board and then the drivers side rear seat panel looks like it got wet at some point. Going to just clean the floor and maybe just use a rust converter on the rust.
    Drag Race Build
      automatic
    Loading...
  8. Mitsubishiown
    131
    10
    Joined Feb 11, 2012
    Davison, Michigan
    22EDFE99-3B5D-4887-B51C-935EA48B800B.jpeg 453E445C-32B6-44DC-A36F-FFDE72A528E6.jpeg Just cleared out the passenger side and the only issue on this side is some panel came up when I took off the sound deadner and it’s rusted underneath it pretty bad. Recommendations on this would be greatly appreciated.
    Drag Race Build
      automatic
    Loading...
Share This Page
Loading...
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
