4g63eagle
- 151
- 0
- Nov 3, 2009
arozonoo,
Africa
I want to switch to synthetic oil, I see royal purple and mobil1 come up the most. Its about 10 extra bucks for the royal purple is it worth it? or is mobil1 5w30 fine?
Note: This feature currently requires accessing the site using the built-in Safari browser.
Just use oil, thats the best kind of oil for your engine. You are not going to gain or loose anything from oil, just change it. 5*F of temperature will make a larger power difference. I use cheap oil in my 10 second car, you?
mobil1 will work just fine. any synthetic oil is all synthetic oil.... mobil1 is just a band wagon that everyone has jumped on... yes it good but other synthetic oils are good aswell.
the only difference between all synthetic oils is the additives in them
MOBIL1 will work dont waste your money on MORE expensive stuff cause mobil1 is already expensive.
Not really. AMSOIL invented synthetic oil and have perfected the formula (as as well as their tranny and gear oils...along with their filters..) and others are just doing their best to make it as close to AMSOIL, but just come in as a close 2nd.any synthetic oil is all synthetic oil
