DogWhistle
Supporting VIP
- 1,033
- 588
- Sep 13, 2012
St. Paul,
Minnesota
So if anyone else is as confused as i was the first 3x times looking at this thread, here is an animation that calms the mind.
Thank you for posting. Great explanation video.
Note: This feature currently requires accessing the site using the built-in Safari browser.
I have the complete manual books for the 95, I can go step by step to explain but it will take for ever, I can take pics and send you all the required pages to get it running so you can figure it out.
You are almos ther with the project, I'm anctious to see it running.
Ok I'm getting power on pin 16 (boost meter) via switch, and ground in pin 71 (ignition switch - ST).
All this test was with the ecu disconnected so let me know what happen.
in your video, do you have 2 sensors reading the mechanical timing? The oem one your asking about and a machined mounted one(exhaust cam)?
This is so awesome! Cant wait to hear it run curious how it will sound! Are you on evom also? I think I may have followed some of your threads years ago?
Yes two sensors. The one in question on the exhaust "cam" and I also have the stock crank angle sensor that has the three wire triangular plug.
This looks like a really cool engineering project. However, I see you have the oem cam gears and timing belt installed (where the gears rotate in the same direction), and the rotary valves rotate in opposite directions. In your last video I saw the gears located behind the cam gears when you were talking about the cam sensor. Do you rotary cams rotate opposite and the cam gears are just there to keep the bottom half timed?
