96gstdsm
- 808
- 2
- Aug 7, 2006
monroe,
New_York
So my Eclipse has been sitting for about 6 months now. I got it started today and it started right up. It was sitting because I bought a new car and also it had some problems after it's build. Idling and stalling and over heating problems mostly.
Now I guess I blew a couple of fuses somehow because my windows and radio don't work. Haven't gotten around to checking them out.
My headlights once turned on, will not turn off. I have to pull the fuse and then put it back in. I do have aftermarket headlights, but I never had a problem with them before. I checked out my horn and it works, but then stayed honking until I disconnected the battery quickly.
My car also keeps stalling once warmed up which I have another thread about. Lots of problems at the moment with it. Also smoking from oil somewhere under the turbo. I guess one of the oil lines is loose or something. Haven't had a chance to jack it up and take a closer look yet.
They were supposed to be plug and play but didn't work so cut them up and wired them together. Was working perfectly before.
Just remembered though that the new battery I got today, my friend put it in backwards at first since the terminals were opposite to how my old battery was and connected one terminal and the second one touched before I stopped him. It sparked up a bit. Would that have friend something possibly? The fuse is good and all for the headlight as they headlight will obviously go on. Just wont go off.
