[RESOLVED] Clutch slips when fluid is hot?? [No, it was pump-up. Again.]
Posted by luisjo, May 30, 2008
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support JNZ Tuning
  1. luisjo
    luisjo Probationary Member
    Apr 17, 2008
    14
    San Juan, Puerto_Rico
    Ok so the problem goes as this.... I changed my master cylinder, and let me tell you the clutch fluid was awfull almost like rotten so i chenged and then i find out that the clutch is slipping, so i change the slave cylinder and it still does the same thing.
    The problem goes like this: I start my car in the morning and the clutch is working like it should grabbing down... so after the car warms up (doesent matter if running or just in the driveway) the clutch will start to slip even in first gear almost wont take off and the cluthc will grab at the end of the pedal, today i figured out that when i does that, i turned off the car and within 30 seconds i sprayed the master cylinder and the lines (without touching the transmision) and turned the car on and the problem was GONE, until it got hot again, i bought a clucth kit today but i know whitin me that is not the problem im really deppressed now because i cant figure the problem out and i need my car ASAP. PLEASEE some one help me what can it be? i remember that when i changed the pump it was raining (you know water expands as it gets hot so it can cause pressure on the system and wont let the clutch grab) but i bled the thing like 3 times, i think i could flush it but i dont know how,
    #1
  2. liquidz28
    liquidz28 Proven Member
    DSM Profiles:
    Jan 29, 2008
    119
    tacoma, Washington
    Hey, dont call out the motor just yet, i had the exact same problem, turned out to be the pedal itself was out of adjustment, check and see how far down your pedal goes down with the motor off, and cold. then warm her up and check again, i found that my pedal actually was changing positions when hot/cold. the pedal was so far out of adjustment that it was actually back to the point where it worked....wich i believe is the end of the rod, if you are there, scroll it all the way back to the base and start your adjustment. what happens is the clutch never actually fully clamps down but feels like it, when your HW gets warmed up just that .009 of an inch feels like a mile and allows the clutch to pull away from the flywheel. check that before you do anything major. on the crankwalk subject, there are tons of ways to test for it on these lovely forums.:rocks:
    #2
  3. luisjo
    Apr 17, 2008
    14
    the clutch pulls away from the flywheel like it should, the thing is that the pedal will star (rising) to the point that i take my foot off the pedal completely and the clutch wont grab "enough" and will slip like there is no tomorrow
    But i have my hanes manual let me check the adjustment and get back to you
    #3
  4. liquidz28
    DSM Profiles:
    Jan 29, 2008
    119
    tacoma, Washington
    HA! exactly what mine was doin, adjust that bad boy, youre fine!:thumb:
    #4
  5. luisjo
    Apr 17, 2008
    14
    well i ajusted the screw to go as far in as posible and drove it like 15 minutes on the street before y started doing the same thing, the clutch pedal gets as hard to press as the brake so there is pressure building up inside the lines don't know how nor why something must be f***ed up and i dont know what it is, again when is cold the car drives normally
    #5
  6. m50
    m50 Probationary Member
    Sep 13, 2006
    3
    St. John's, Newfoundland_Canada
  7. No_Skillz
    No_Skillz Proven Member
    DSM Profiles:
    Dec 8, 2004
    1,925
    24
    Freehold/Morris, New_Jersey
    Thank you m50. (Although I suggest you use spell check LOL Basically you need to adjust the pedal to a point where it's completely engaged well before the pedal is all the way up.
    In addition to pump up, you need to bleed well. Could be that the air in the system expands when it gets hot and is screwing with you.
    #7
  8. luisjo
    Apr 17, 2008
    14
    i was reading Pedal pump up just about now, but i didnt understand well what i need to do (my english can only go so far since spanish is my native tongue) the thing is that the "bolt" that came with the pump was ALOT larger than the other one it had (i assume OEM) so i cut it to alittle bigger than the stock one, the screw is all the way in it can go so i dont know what to do, also it talks about a release valve in the master cylinder se photo, i dont know what that is, thanks
    http://www.roadraceengineering.com/eclipsetech/clutch/2g-clutcumastercyl-guts.jpg
    #8
  9. No_Skillz
    DSM Profiles:
    Dec 8, 2004
    1,925
    24
    You cant see the release valve unless you take apart the master cylinder. Like I explained, the basic jist is to adjust the pedal to a point where the clutch is completely engaged before the pedal is all the way up.
    #9
  10. luisjo
    Apr 17, 2008
    14
    Ok, so i took out the screw and cut it using a grinder, then installed again so it could go all the way out, the problem was really simple i opened up another master cylinder and found the release valve is a tiny button located like .09 of an inch before the pedal goes all the way out, so even the slightest mis-adjustment will create the thing known as "pedal pump up".... i solved my problem and maybe some other dude with the same problem... i haven't tested the car yet but tomorrow i will to see results...
    #10
  11. str8boostin
    str8boostin Probationary Member
    Jul 8, 2006
    New Hyde Park, New_York
    Does anyone know what would cause my clutch to do this?
    The previous owner gave me the reciepts that he had when he had the trans rebuilt. He also upgraded to an ACT 2600 and ACT Flywheel and all of this was done under 8,000 mile ago.
    Anyway it happens after about 20 minutes of driving, I'll go to put it in 3rd or 4th and it will just slip from 3k. It builds boost but just doesn't go anywhere and it only happens after I've been driving alittle. I don't really feel and difference in the clutch when this happens either. If its cold I can pull to 6k+ no problems. I know the car has been sitting a while and I really only just got it running about 2 weeks ago but I'm not really sure what could be causing this? I'm thinking of ordering a ss clutch line, bleeding the system, and hoping that it was just water/air in it. Any other suggestions? Possible clutch is going already?
    Thanks John
    #11
  12. SiNiST3R
    SiNiST3R Proven Member
    May 10, 2004
    237
    NorCal, California
    Get under the car pull the little rubber boot back on the transmission you cant miss it, see if the clutch is yellow that will tell you if its a ACT.
    #12
  13. kris_stewart10
    kris_stewart10 Proven Member
    Jul 16, 2008
    332
    Picayune, Mississippi
    could be the same thing that happened to me too much power(but i was on a stock clutch) which is designed to slip to an extent but it shouldnt happen to an act 2600 i think its that the material is getting heated up and not engaging that well so i dont know
    #13
  14. Defiant
    Defiant DSM Wiseman
    DSM Profiles:
    Jan 13, 2003
    25,202
    117
    glorious Galt, California
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
