replacing speed sensor
eclipsemaniac
46
Jan 15, 2012
weaverville, North_Carolina
I have 99 eclipse rs. My speedometer quit working so i checked the speed sensor out and it wasn't putting the proper voltage out. I bought a new one and went to replace it, I unplugged it and removed the one screw. I went to pull it out and had to pull hard and a piece came loose from it and fell down in the hole where the speed sensor goes. My question is what was that piece, and if anyone has any idea how to get it out of the transmission? thanks for any suggestions
You shouldn't have to pull very hard to remove the speedometer sensor. You probably broke off the plastic gear on the end of the sensor. Unfortunately there's no easy way to remove it, so you'll have to leave it there unless you pull apart the transmission.
so leave the plastic gear in there and just get another one?
Does anyone know what the gear on the end of a speed sensor for a 99 eclipse rs is called? thanks
