Replacing Front Speakers
Posted by need2speed75, Nov 10, 2011
Appearance/Interior/Exterior - All interior and exterior tech discussions; body and paint, conversions, lighting, washing, waxing, etc.
Please Support Strictly Performance Motorsports
  1. need2speed75
    need2speed75 Probationary Member
    Oct 28, 2011
    17
    papillion, Nebraska
    Passenger side front speaker is blown and would like to replace it. I don't have the infinity sys so I believe the size is 5 1/4. Which aftermarket speaker do you all recommend to replace that doesn't require much modification and is a direct fit? Also would I need to get specialized speaker bracket for it? Not looking for anything special, just ones that works.
    #1
  2. NeMiZiS
    NeMiZiS Supporting Member
    DSM Profiles:
    Jul 25, 2007
    1,354
    14
    Anchorage, Alaska
    #2
  3. eclipsemf
    eclipsemf Supporting Member
    DSM Profiles:
    Jun 10, 2010
    193
    Glen, New_Hampshire
    I run alpine type s in my fronts. They sound nice and wernt to expensive, and they were a direct fit! Just something to look in to.
    #3
  4. ryztriumph
    ryztriumph Proven Member
    DSM Profiles:
    Aug 30, 2011
    152
    Harrisonburg, Virginia
    I was thinking of replacing the front speakers in my GST, the drivers side doesn't work, but the pasenger side is good. It's the infinity system idk if the size is different. They are 6-3/4 I think. Let me know if you want it.
    #4
  5. NeMiZiS
    DSM Profiles:
    Jul 25, 2007
    1,354
    14
    Anchorage, Alaska
  6. TWOpointFORliter
    TWOpointFORliter Proven Member
    DSM Profiles:
    Jul 31, 2009
    364
    3
    Crown Point, Indiana
    You can easily fit 6 1/2 speakers in the front. I have put 6 1/2's front speakers in all my dsm's. No trimming required just have to drill new mounting holes. Since it is plastic you could just use a drill and screw the screws in were you need them.
    #6
  7. ryztriumph
    DSM Profiles:
    Aug 30, 2011
    152
    Actually you probably don't want mine. I got some new ones today and got a good look at the old ones for the first time. They are really screwed up. Which is funny, because the right side sounded fine. No distortion or anything.
    [​IMG]
    #7
  8. Blue Talon Boy
    Blue Talon Boy Proven Member
    DSM Profiles:
    Sep 22, 2010
    262
    Leesburg, Virginia
    Those things are pretty toasted. I'm surprised you couldn't hear a difference...
    Sent from my ADR6300 using Tapatalk
    #8
  9. ryztriumph
    DSM Profiles:
    Aug 30, 2011
    152
    Well I can definitely hear the difference now. It sounds 100x better than it did!!
    #9
  10. Boostinsideways
    Boostinsideways Banned Member
    DSM Profiles:
    Feb 4, 2011
    1,125
    7
    Arab, Alabama
    Mine were blow that bad, but they didn't sound terrible. Just no base what so ever.
    #10
  11. ryztriumph
    DSM Profiles:
    Aug 30, 2011
    152
    Yeah, I couldn't really tell that there was no bass because of my bazookas. They do a pretty good job. Now, with the new speakers in, they sound so deep and sexy! I wish I'd replaced the speakers when I got the car. I guess you can't do everything at once!
    #11
  12. 2slow4now
    2slow4now Freelancer
    DSM Profiles:
    Nov 20, 2008
    910
    34
    otwell, Indiana
    I used some cheap Blaupunkt 6.5" and they sound ok but the bolt pattern wasn't big enough and I had to make a reducer ring for them to fit the door hole. I would get dimensions of whatever your thinking of buying and compare it to the stock hole.
    #12
  13. Black Widow97
    Black Widow97 Supporting Member
    DSM Profiles:
    Sep 2, 2010
    2,624
    14
    Sioux Falls, South_Dakota
    I alleays get pioneer. Theyre inexpensive and i have never had a problem with them.
    Sent from my DROIDX using Tapatalk
    #13
  14. ryztriumph
    DSM Profiles:
    Aug 30, 2011
    152
    Pioneer is what I got. They sound good and they were cheap! What else do you need? :rocks:
    #14
  15. Stealth93
    Stealth93 Proven Member
    Aug 13, 2011
    32
    Wichita, Kansas
    ^ ^ ^ Pioneer is definately good sounding, went with those in my Stealth front and rears
    #15
  16. bryceorbiter
    bryceorbiter Proven Member
    Jan 14, 2008
    54
    Freeland, Michigan
    I used some random tiny speakers i had laying around, a little bit to small to fit in the plastic cradle correctly, i used some cardboard and zipties to make it work until i could get some nice speakers. If your in a pinch that is what i recommend.
    For easily connecting speakers i just solder some wires to the speaker I'm putting in's terminal, then on the other end crimp some male quick disconnects. That way i can maintain the stock harness and easily switch speakers around.
    #16
  17. Boostinsideways
    DSM Profiles:
    Feb 4, 2011
    1,125
    7
    Arab, Alabama
    Meh I prefer larger full range speakers to subs or boom tubes. I really would like to figure out a way to run some 10s in the back preferably in the stock location or once I delete my rear seat I will figure something out, and 8s in the doors. I know the 8s in the doors is doable. Then I will probably replace the factory amp with something that can actually give all 4 juice.
    #17
  18. Rich_Howell
    Rich_Howell Proven Member
    Nov 10, 2009
    43
    South Bay Area, California
    There is no such thing as a full range speaker. Going larger will increase the amount of midbass you can achieve, but going larger also decreases accuracy in the higher frequencies. You will never get door speakers to produce the bass a subwoofer produces, even if you go with 8s in the doors. Believe me...been there. The rear enclosure room for the OEM 6x9s isn't even close to what you would need for a 10"...even if it was of the shallow-mount variety.
    Achieving useful midbass in the doors of our cars is perfectly do-able. It can be done easily with 6.5" drivers in modified stock enclosures. Search: aperiodic enclosures.
    The point isn't to get "awesome bass from the doors"...it's to make the doors hit low enough to make you believe the corresponding bass from the sub(s) is coming from the front. The mids provide the "attack" of the bass hit (the frequency range that is locatable by our ears) and the sub fills-in the lower frequencies that are not locatable. Rear speakers do you a huge disservice in this arena. The locatable/non-locatable point is right around 100Hz. If you can get your doors to play lower than that, it makes it easier to perform the illusion. I have 6.5s in my doors right now (Diamond Hex) that I crossover at 50Hz (but with a really steep 24dB/octave slope) and they sound amazing. Like most things: it's all in the tuning.
    Even though I have great midbass in the doors, I still have dedicated drivers for midrange (in kickpanel pods) and dedicated drivers for high frequencies...even ones for super-high frequencies (above 20kHz). No ONE speaker does it all. That's like saying there is ONE turbo to cover the range from 210hp to 1200hp. Use each component in your system for it's inherent advantages. Trying to make things perform outside their intended design parameters is how you blow things up.
    #18
  19. dalesmitsu
    dalesmitsu Proven Member
    DSM Profiles:
    Jul 23, 2006
    346
    North Canton, Ohio
    Crutchfiled as an excellent place to buy from, deals everyday and they're Newbies friendly too. :D Comes with a master sheet instruction and harness lit for free. Which would save anyone a few bucks.
    Pioneer Head with Inifnity speakers is a great combo, budget friendly.
    My first car 89 cutlass ciera has this setup my brother who is a system freak. Thought I had 10's in the rear when I told its 6x9s he :ohdamn: and I laughed at him.
    #19
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
