doubleclutch
- 830
- 175
- Jun 26, 2009
Canton,
Michigan
Hey guys,
My hard work has paid off and I am now making more power then my clutch can handle (believe it is stock). I was in the middle of a pull and RPMs go ^ and no acceleration. I plan on deleting the accumulator and removing the check valve while I am in there so the pedal stops hitting me in the bottom of the foot when it is cold. Aside from that, what else is a good idea to remove/replace/upgrade? Any comments on my component selection? Any pitfalls to look our for? I heard that the flywheel must be stepped down 0.612" +/- 0.002" and should be ground instead of turned.
HP goal is 300 WHP/400 Crank HP.
ACT 2600
Resurfaced Lightened Flywheel (was replaced 20K ago by PO)
Extreme PSI SS complete line
OEM Throw Out Bearing
Bearing Retainer Clip
Competition 4140 Fork and Ball
ARP Flywheel Bolts
OEM Pressure Plate Bolts
Driver Side Axle Seal
Passenger Side Axle Seal
Transmission Output Seal
T-Case Input Seal
T-Case Output Seal
Redline MT-90 for Tranny
Redline 75W-90 for T-Case
ACT 2600
ARP Flywheel Bolts
T-Case Input Seal
T-Case Output Seal
