Replacing bent valves
Posted by mrjsauce, Sep 21, 2011
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support ExtremePSI
  1. mrjsauce
    mrjsauce Probationary Member Wilmington, North_Carolina
    DSM Profiles:
    Sep 20, 2011
    5
    Ok so i bought a 1990 eclipse gst for 400 dollars recenlty and obviuosly it had some issues the main one being broken timing belt and bent valves, i gues my question is are there a certain brand or type of valves i should replace them with and what kind of difference they can make with my performance.
    #1
  2. JusMX141
    JusMX141 Moderator Greensburg, Pennsylvania
    DSM Profiles:
    4
    Dec 13, 2005
    12,583
    543
    If only the intake valves are bent you can get away with just swapping the valves- if you have bent exhaust valves, it's highly recommended that you replace the guides as well. The exhaust valves are much stronger than the intake valves so when they contact the piston there is a tendency to do guide damage that may go unnoticed until you've already assembled the engine.
    Using OEM replacement parts are fine.
    #2
  3. g4ebguy90
    g4ebguy90 Proven Member Rockford, Illinois
    Mar 9, 2011
    755
    You can pick up a used head, cheaper then probaly buying all the parts, and paying labor to fix the one you got.
    I usually sell good condition heads with all valves springs etc etc, for around $100 on average.
    Valves usually cost $10.00 each. Not including labor to remove and install.
    #3
  4. mrjsauce
    DSM Profiles:
    Sep 20, 2011
    5
    i do beleive i have bent exhaust valves im not looking at it right now so idk for sure but i am going to double check. thanks for the input and i probably will just go with oem.
    thanks g4 that seems like a good idea seeing as all the quotes ive got on fixing it are much higher than $100, roughly how much does shippin usually run. i live in NC
    #4
  5. g4ebguy90
    Mar 9, 2011
    755
    Please private message me. Thanks.
    #5
  6. coop795
    coop795 Proven Member Meridian, Idaho
    Aug 5, 2008
    70
    when you take the head off you need to check the pistons, if you smacked them you should replace them. we run boost and they will break if they are cracked.
    #6
  7. g4ebguy90
    Mar 9, 2011
    755
    Turbo pistons are actually quite strong. If you have ever had one out of the engine. They are quite beefy. I have dropped a couple before... crappy ones, like 4 feet onto concrete, the tops might get a scratch, the sides might dent in a bit, but they are pretty tough.
    As long as the valves were just bent, not broken or sunk into the head itself, like embedded then I wouldn't worry about the pistons to much.
    #7
  8. mrjsauce
    DSM Profiles:
    Sep 20, 2011
    5
    The pistons look fine they didnt get smacked too bad
    #8
  9. g4ebguy90
    Mar 9, 2011
    755
    Hey I did send you a private message. Look in the top right corner of the webpage. You will see the option to click on it. Should be a flashing notification.
    #9
  10. ontario AWD
    ontario AWD Proven Member North Bay, ON_Canada
    May 27, 2008
    89
    Make sure you take a light and check the bottom of every guide that had a bent valve.Most will have hairline cracks that if you tweak on a little bit will break away.Not good to have floating around in your cc.
    #10
  11. fbc-eclipse
    fbc-eclipse Proven Member denver, Colorado
    DSM Profiles:
    Sep 4, 2008
    49
    i would recommend a full head rebuilt, do it once and save money.
    #11
  12. bryanwheat
    bryanwheat DSM Wiseman Columbia, Missouri
    Aug 16, 2004
    6,952
    157
    This could probably mean ten different things depending on which machinist you talk to. Some might consider just a clean and a valve grind a rebuild, some might consider new guides, new seats, new valves a rebuild. The best way to go about head work is to repair what is damaged and out of spec in this case it is the valves and most likely the guides. You would replaced the cracked guides, check the rest for internal diameter. Freshen up the seats. Freshen up the valves, lap them to the seats, surface, clean and assemble.
    #12
  13. iugrad92turbo
    iugrad92turbo Proven Member Kalamazoo, Michigan
    DSM Profiles:
    May 22, 2007
    10,198
    242
    Oem ones are just fine, which ever shop you go to they will look at it and see what needs to be done, i work closely with my machinist but, if your goals are stock you should be fine with oem valves.
    #13
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
